Precision Intercooler Question
Old Mar 11, 2004 | 10:20 PM
TURBODC4TEG's Avatar
Default Precision Intercooler Question
will the precision Intercooler 31.5x8x3.5 fit rev hard intercooler piping?
just got my intercooler need to know asap
thanks
Old Mar 11, 2004 | 10:38 PM
Default Re: Precision Intercooler Question (JDMDC4TURBO)
anyone know??? i need to know before i try to put my intercooler and the rubber connector doesn't work
Old Mar 11, 2004 | 11:00 PM
up
Old Mar 12, 2004 | 04:48 AM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC4TURBO &raquo;</TD></TR><TR><TD CLASS="quote">will the precision Intercooler 31.5x8x3.5 fit rev hard intercooler piping? </TD></TR></TABLE>
Well seeing as how the satndard Revhard/spearco intercooler is not as long as the precision, everything should line up after you cut off a couple inches off each side. Just mount it, and then see how muc cutting modifying you need to do. shouldn't be nothing a Hacksaw won't fix
Old Mar 12, 2004 | 06:17 AM
PrecisionH23a's Avatar
Default Re: Precision Intercooler Question (quikB18B)
If the rev-hard uses a 2 1/4" pipe and the IC has 2.5" outlets simply take the IC piping to a local muffler shop and have them flare the ends out to a 2.5" That way you won't have to buy expensive silicone coupled flares.
Old Mar 12, 2004 | 10:06 AM
Default Re: Precision Intercooler Question (PrecisionH23a)
u sure i will have to cut the piping?
i was just wondering about the couplers if they would fit, i did a test fit and the pipings tip goes into the inlet on the intercooler not much maybe the couplers will scretch alittle?
Old Mar 12, 2004 | 10:19 AM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC4TURBO &raquo;</TD></TR><TR><TD CLASS="quote">u sure i will have to cut the piping?
i was just wondering about the couplers if they would fit, i did a test fit and the pipings tip goes into the inlet on the intercooler not much maybe the couplers will scretch alittle?</TD></TR></TABLE>
Messure the revhard piping and the FMIC. The precision FMIC is 2.5" on both ends i think.
liam
Old Mar 12, 2004 | 10:48 AM
Default Re: Precision Intercooler Question (liam821)
i know the endtanks on the precision intercooler is 2.5 i just need to know u guys think the rev hard piping and couplers with fit
thanks
Old Mar 12, 2004 | 11:00 AM
quikB18B's Avatar
You'll need to run a transition piece for it to connect. I know for a fact Revhard piping is not 2.5 inches from the turbo to inlet of intercooler. Also you'll want to doubel check the size of the precision intercooler inlet/outlets. Mine(the small one) is 2.5 and i beleive the middle one(the one you have)is also 2.5, but the big PT&E intercooler uses 2.75 inlets/outlets.
Either way you'll need to get a transitoin piece, just measure the piping(its either 2" or 2.25) and then you have the middle sized Pt&E FMIc.
In the end you'll prolly have to cut off a couple inches, and run a transition piece, and thats it noting major. http://www.atpturbo.com sells the transitions for pretty cheap $17.50
Good luck
jdm inc
Jul 30, 2006 12:38 AM
White_EK49
Welding / Fabrication
Apr 17, 2006 11:16 AM
See Are X
Sep 9, 2004 03:02 PM
