How 2 remove side molding on a 92 civic hb Dx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">???</TD></TR></TABLE>
Take off the door panel, inside the door, there are clips that you compress in order to pop the molding off, also, right where the edge is, you'll find a small bolt that needs to be removed as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">
Take off the door panel, inside the door, there are clips that you compress in order to pop the molding off, also, right where the edge is, you'll find a small bolt that needs to be removed as well. </TD></TR></TABLE>
there will be lots of holes left behind, if you think you can just take them off and have them be gone.
Grandhustleman86
Jul 30, 2007 07:33 PM
E.Honda
May 29, 2007 06:15 PM
