motor swap help please
Old Mar 11, 2004 | 08:54 PM
bigtony's Avatar
Default motor swap help please
hey whats up i need some help iv just got into honda and im planing on doing a b16 motor swap on a obd1 civic can eny one help me and tell me what i need to do it thanks.
Old Mar 11, 2004 | 09:10 PM
Kendall's Avatar
First off, learn to use the search function. You should be able to find all you need to know.
Assuming your car is already equipped with a manual transmission, then the swap is as straight forward as it gets. Assuming you don't already have a VTEC wiring harness, then you'll need to run 3 wires, one for the VTEC solenoid, one for the pressure switch, and a chassis ground. Everything else is pretty much as straight forward as it gets.
Old Mar 11, 2004 | 10:41 PM
girls call me pogi's Avatar
Default Re: motor swap help please (bigtony)
Check out the Hybrid section of this forum. They specialize in motor swaps, whoadie.
patrick123
Jul 22, 2011 09:52 AM
andrewcruzcrx
Jul 13, 2008 07:03 PM
stehigs321
Nov 4, 2002 09:23 AM
