turboing a accord
hey....i got a 97 accord with a f22b1 engine which is 2.2L 145HP. I'm was thinking about getting a H22 swap but heard that just turboing it would be the better. My car is an automatic so do u think I would be better off going with turbo or the H22 swap?
i would turbo it.......there company selling a turbo kit out there for under 2 grand......boost about 9psi for daily driving.........
turbo is the way to go ........just the sound of it is niceeeee.
Turbo would be nice on that motor (8.5:1 CR), turbo loves lower CR's.
.....but the auto tranny may not like it.
For some "get up and go", get a H23 swap.
For all out power, get a H22 swap.
BTW, are you staying with the AT, or going with a MT swap?
the f22b1 will be aight with the boost but your auto tranny won't like it. You will make more hp than the h22 but only with the right stuff and good tunning. i say get an h22 and boost it
alright man i would say go with the h22 swap with mt. you can get one for bout 2200 plus shipping. check it out on http://www.totaljdm.com. it comes with about everything you need. then start to modify.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bukkake03 »</TD></TR><TR><TD CLASS="quote">alright man i would say go with the h22 swap with mt. you can get one for bout 2200 plus shipping. check it out on http://www.totaljdm.com. it comes with about everything you need. then start to modify.</TD></TR></TABLE>
first thing first, a h22 with accord 5speed tranny is crappy enough(for NA), let alone auto accord long gear ****.
even with the h22, the car aint that much faster neither.
it wouldnt have an accord 5 speed. because he would be replacing his auto tranny. the package comes with a prelude 5 speed. and after you get that in the car you start to mod the engine. cams, pulleys, pistons and such.
Cars: JDM 92-96 Prelude VTEC
Mileage: 28,000-45,000 miles
2157cc (DOHC VTEC)
Horsepower: 200hp@6800rpm
Torque: 161lbs-ft@5500rpm
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 1
Redline: 8200rpm
and then when you went to turbo it just make sure you tune everything right
2157cc (DOHC VTEC)
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 1
Redline: 8200rpm
