skunk2 im and stg 2 cams???
Old Mar 11, 2004 | 05:34 PM
FlipboiGSR's Avatar
New User
Default skunk2 im and stg 2 cams???
Do i need a header or a bigger exhaust system with it or would these work fine with a stock gsr with an intake (aem cai)???
If i need exhaust/cat what size piping do i need.
If i had the money I would get JDM header, comptech exhaust, with the im and cams but i only have 1400 to spend.
thanks
Old Mar 11, 2004 | 05:59 PM
TRuST's Avatar
Default Re: skunk2 im and stg 2 cams??? (FlipboiGSR)
I wouldn't spend the money on Stage 2 cams now nor the manifold until you have things that would require them.
From your post, I'm assuming that your pretty much stock. I would start with I/H/E. If I had 1400, I would get an ITR header, any aftermarket exhuast, and may be ITR cams or save another couple hundred and go turbo.
Old Mar 11, 2004 | 07:57 PM
kaptr1d's Avatar
im still on a stock exhaust manifold with skunk2 stage 2's.
I plan on getting an an-r header very soon though and i have an itr i/m in the mail.
u really need to let the motor breath more to capitalize on the stage2 camshafts, but ull still feel a power gain from swappin them in.
after u finish basic bolt ons the cams will reach their full potential.
Old Mar 11, 2004 | 10:45 PM
eyeamvic's Avatar
Skunk2 stage 2 cams without compression and tuning to back them up? Doesn't sound like a good idea. Don't start a project unless you're ready to do it right. When you go with bigger cams, both tuning and compression is a must. And generally all the bolt-ons should be done prior to that.
Old Mar 11, 2004 | 10:49 PM
girls call me pogi's Avatar
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 stage 2 cams without compression and tuning to back them up? Doesn't sound like a good idea. Don't start a project unless you're ready to do it right. When you go with bigger cams, both tuning and compression is a must. And generally all the bolt-ons should be done prior to that.</TD></TR></TABLE>
Well said.
I'd go with a Comptech header, or if you have money, something a little crazier.
Leo's 07 Honda Civic Si
Honda Civic (2006 - 2015)
35
Sep 14, 2009 08:04 PM
Eric R
Dec 24, 2003 09:07 AM
vtecdc2
Sep 5, 2002 11:20 PM
flashgsr
Aug 28, 2002 07:40 PM
spankaveli
Feb 13, 2002 04:16 PM
