msd rpm switch for vtec, what voltage does the solenoid need?
Old Mar 11, 2004 | 05:29 PM
spettinger's Avatar
Default msd rpm switch for vtec, what voltage does the solenoid need?
90 hf, single cam vtec motor, want to send out the correct voltage so as not to fry the solenoid. thanks.
Old Nov 18, 2004 | 12:08 PM
gotboostedvr6's Avatar
Default Re: msd rpm switch for vtec, what voltage does the solenoid need? (hatchofchrist)
bump
Old Nov 18, 2004 | 01:21 PM
Kataku2K3's Avatar
Default Re: msd rpm switch for vtec, what voltage does the solenoid need? (gotboostedvr6)
12V+. I'm sure you're familiar with how to set it up but this will make it quick. Off the MSD RAS red = 12V+, black = ground, white = rpm signal, yellow to the 85 pole on a standard relay. Run another switched 12V+ source the relay's 30 and 86 poles (85 and 86 can be vise versa, it really doesn't matter). Then run 87 out to the VTEC solenoid. The VTEC solenoid doesn't pull a ton of current either but be careful what you get your switched power from.
Old Nov 18, 2004 | 01:45 PM
Default Re: msd rpm switch for vtec, what voltage does the solenoid need? (Kataku2K3)
thanks
HatchEh2
10
Jun 3, 2006 09:37 AM
DsBananas94LS
Dec 5, 2004 07:51 PM
racingant
Feb 3, 2004 08:29 PM
s2000june
16
Jan 31, 2004 06:55 PM
