ats final drive install help
Old Mar 11, 2004 | 04:56 PM
allmotorjay's Avatar
Default ats final drive install help
Anyone run into any clearance problems with first gear rubbing against the differential when tightening done the tranny case.There seems to be no clearance between the gear and the diff.The tranny is JDM type R so all I should need is the shaft and ring gear.
Old Mar 12, 2004 | 01:14 PM
acy76's Avatar
Default Re: ats final drive install help (allmotorjay)
I don't know about the ATS set specifically, but there isn't much clearance between the 1st gear and ring gear until the countershaft is pulled up and held in place by the snap ring during assembly.
paopao
Transmission & Drivetrain
Jun 14, 2010 10:40 AM
GsxrCX
Feb 25, 2004 02:36 PM
RS_91
Aug 27, 2003 07:31 AM
