Check List...
Old Mar 11, 2004 | 04:19 PM
ranta18's Avatar
Default Check List...
What else do I need for my new H22 build-up? For the motor only, not intake, exhaust, or tranny stuff.
I'm ordering the following new:
88mm 12.5:1 IB/Wiseco Pistons
ARP Head Studs
OEM Head Gasket
OEM Oil Pump
OEM Timing Belt
OEM Main Bearings
OEM Rod Bearings
OEM Rod Bolts
OEM Main Bolts
Hondata Intake Manifold Gasket
I already have new:
Golden Eagle Block
OEM Water Pump & Gasket
OEM Rear Main Seal
OEM Oil Pan Gasket.
Manual Timing Belt Tensioner
Crower Stage 3 Camshafts, Springs, & Retainers
STR Cam Gears, Cam Seals, & Fuel Rail
Modified by ranta18 at 7:23 PM 3/12/2004
Old Mar 12, 2004 | 10:20 AM
ranta18's Avatar
Default Re: Check List... (ranta18)
Any suggestions?
Old Mar 12, 2004 | 10:29 AM
KTeller8's Avatar
kinda like mine but i am going AEBS studs and i dont know if you had ACL's in there..
but that and at least a head clean up and motor work is always a plus.. need to help that new increased air flow
Old Mar 12, 2004 | 09:40 PM
cracker099's Avatar
Default Re: Check List... (KTeller8)
Use ARP rod bolts instead. only 36ish bucks. Alot stronger than OEM
Old Mar 12, 2004 | 11:54 PM
Suprdave's Avatar
Are you having everything machined for floating pin?
Race Motor, why so low of compression....go bigger on that bore.
Old Mar 13, 2004 | 12:53 AM
h22John's Avatar
This might be kinda out there but a baffled oil pan is always nice, or a dry sump system Sorry all I can think of at the moment, every little bit counts right?.Ohhhh, radius valve job? I dunno....................John
Old Mar 13, 2004 | 07:36 AM
ranta18's Avatar
Default Re: Check List... (h22John)
I don't think ARP makes rod bolts for it, just the head studs.
The head is shaved .020, so the compression will be 13:1 or a little higher. I'm having a bunch of machine work done and a port and polish on the head, but I didn't put that in the list as something I need to "buy" because its something thats getting done.
Look at this!!!
OEM:
Head Gasket $55.88
Oil Pump $152.74
Timing Belt $38.84
Head Bolts (10) $8.19 = $81.90
Dowel Pin (2) $.80 = $1.60
Main Bearing (10) $8.89 = $88.90
Rod Bearings (8) $9.92 = $79.36
Rod Bolts (8) $3.66 = $29.28
Main Bolts (10) $6.80 = $68.00
Total = $596.50
Thats a lot more than I was thinking. That **** adds up quick!
Modified by ranta18 at 5:58 PM 3/13/2004
GTsmurf
Sep 11, 2013 07:22 AM
TaylorC01
Aug 27, 2006 01:59 PM
Vsm Hatch
Dec 30, 2004 12:16 AM
ranta18
Mar 13, 2004 09:58 PM
