bits for porting/polishing
what kind of bits, tools do most of the pros use for porting/polishing. places to buy etc?
drum rolls, mounted points, etc.
does anyone use any metal bits?
show me some links
show me some links
Standard abrasives makes several kits that are perfect for our cars/heads Summit sells just about any kit they make and they have some for great prices too. (i.e. under $30)
I think this is the kit i used and had a ton left over.
http://store.summitracing.com/...60001
this isn't bad too.
http://store.summitracing.com/...G1060
this isn't bad too.
You're going to want something like this
http://buy1.snapon.com/catalog...talog
they're called 'burrs,' for use with air powered die grinders
I used some extra large ones from this seller on ebay and still use them on my manifolds and stuff, only takes a second on the aluminum though, go easy on it they like to cut quick!
the longer ones are nice to get down in there.
http://cgi.ebay.com/ws/eBayISA...12578
http://www.mondello.com/ then click on the catalog section
or
http://www.goodson.com/
Also, you can look up part numbers for the Standard Abrasives stuff here (good if you need a whole kit, not just bits) and order them through Summit.
http://www.sa-motorsports.com/products.shtm
or
ehansford22
Jan 19, 2014 07:17 PM
RACEPAK
Welding / Fabrication
May 30, 2007 02:07 PM
SmOkIneLf
Jun 8, 2006 03:30 PM
