full coilovers or koni yellows plus sleeves?
Old Mar 11, 2004 | 02:53 PM
kbplaya's Avatar
Default full coilovers or koni yellows plus sleeves?
what would u recommend for a really stiff and no bodyroll ride?
full coilover system
or
koni yellows plus stiff sleeves
please leave brand names and models, thanks
Old Mar 11, 2004 | 03:04 PM
Ti3d in's Avatar
Default Re: full coilovers or koni yellows plus sleeves? (kbplaya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kbplaya &raquo;</TD></TR><TR><TD CLASS="quote">what would u recommend for a really stiff and no bodyroll ride?
or
Koni yellow's with custom rate GC's are a proven setup. Plus you can go as stiff as you want, and its more affordable than a full adjustable coilover setup.
Old Mar 11, 2004 | 03:15 PM
purplegsr's Avatar
https://honda-tech.com/zerothread?id=783327
some people argued over this topic recently in this thread.
I would go with custom rate GCs and Koni's, its a very flexible setup. I have Tein SS coilovers, and it is okay, but I wouldnt describe it as stiff without body roll.
Tanabe Sustec Pros are pretty crazy if you want something really stiff.
Old Mar 11, 2004 | 05:22 PM
Kendall's Avatar
I'm running Ohlins PCV's, but odds are you don't want to spend that kind of money. If I every get rid of this setup, I'll more than likely go with the Koni's and GC's.
Old Mar 22, 2004 | 01:04 PM
partsguyonline's Avatar
I have a set of yellow koni w/groundcontrol with harder spring rate...has the GS's collar for the shocks.
Old Mar 22, 2004 | 01:19 PM
hmongboyLS's Avatar
if money was no object i would get the JIC FLTA2-RS... it's custom rate to what you want like GC's... but if money was, i'd get the GC with koni's... i myself, is planning to get some GC with custom rates and koni yellows... correct me if i'm wrong, but i don't think there's any difference with sleeves compare to threaded body shocks
Old Mar 22, 2004 | 03:27 PM
Default Re: full coilovers or koni yellows plus sleeves? (hmongboyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongboyLS &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, but i don't think there's any difference with sleeves compare to threaded body shocks</TD></TR></TABLE>
we'll you could just fit the gc's on the koni seats, but cant lower as much cause the cup's in the way, to make it look and ride like a full body coilover, gc's sell an adapter that sits on the koni rings, cost like an extra $100
selling this set for $565 shipped....comes with the energy urethane bushing on top cup
Old Mar 22, 2004 | 03:43 PM
94civicEX's Avatar
What spring rates are the people that have the Koni/GC setup going with? GC reccomended 400/300. I have Koni's right now with Comptech springs and want to go with a custom GC.
Has anyone revalved their Koni's after getting the GC's, and how low are you guys going?
Old Mar 22, 2004 | 03:44 PM
Default Re: (94civicEX)
I have those spring rates 400/300....
Old Mar 22, 2004 | 03:45 PM
94civicEX's Avatar
Default Re: (partsguyonline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by partsguyonline &raquo;</TD></TR><TR><TD CLASS="quote">I have those spring rates 400/300....</TD></TR></TABLE>
On what shock? How do you like them?
Old Mar 22, 2004 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicEX &raquo;</TD></TR><TR><TD CLASS="quote">
On what shock? How do you like them?</TD></TR></TABLE>
yellow koni, I have to loosen the dampening, so the ride is not as ruff, but once you tighten them the car doesnt squat at all for strip/street. with the collar you could lower the car to the ground...
Old Mar 22, 2004 | 03:51 PM
94civicEX's Avatar
yellow koni, I have to loosen the dampening, so the ride is not as ruff, but once you tighten them the car doesnt squat at all for strip/street. with the collar you could lower the car to the ground...</TD></TR></TABLE>
So you like it or is it to harsh? How low are you set right now and what are your Koni's set at?
Old Mar 22, 2004 | 04:05 PM
jonsteR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicEX &raquo;</TD></TR><TR><TD CLASS="quote">What spring rates are the people that have the Koni/GC setup going with?</TD></TR></TABLE>
450/400
Old Mar 22, 2004 | 04:07 PM
94civicEX's Avatar
Default Re: (jonsteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonsteR &raquo;</TD></TR><TR><TD CLASS="quote">
450/400</TD></TR></TABLE>
How do you like it? How low? What is the car used for?
Old Mar 23, 2004 | 12:03 PM
jonsteR's Avatar
The car is my daily driver. Used to autox and HPDE with it (hopefully i'll get back into it.) I have no complains on track or street. I'm lowered about 2 inches. This is on a 92.
Old Mar 23, 2004 | 02:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: full coilovers or koni yellows plus sleeves? (partsguyonline)
No it doesn't, regular GC's are $299 and Koni versions are $339.
Actually GC now makes 2 different sleeves for Koni shocks. This one sits on the snap ring like in your pic:
And this one fits over the entire shock:
Old Mar 23, 2004 | 02:34 PM
Default Re: full coilovers or koni yellows plus sleeves? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
lol....this whole forum is just to prove each other wrong....
that means my koni shocks on groundcontrols are a killer deal for $550
Old Mar 23, 2004 | 02:39 PM
Community Builder
indeed, my Konis were 500 alone, 2 years ago... I might consider those longer sleeves when I switch my springs out for GC's, I'll have to call them up and see about them.
Old Mar 23, 2004 | 02:41 PM
fergy016's Avatar
koni yellows
ground controls
comptech sway bar tie bar combo
or
itr sway bar with mount kit.
sway bar is the main thing that will reduce body roll.
ps I always believed skunk2 coil overs were more for track and gc/koni yellows were more for street because of how they rode. the skunk2 set-up is way stiffer.
Old Mar 23, 2004 | 03:27 PM
Community Builder
Default Re: full coilovers or koni yellows plus sleeves? (fergy016)
maybe stiffer than the Special Edition GC's, but you can get springs for GC's that are alot stiffer than what comes w/ the S2's.
And IMHO the way the GC sleeves mount up to the Koni shocks 0wnz all other sleeve-type coilovers.
Old Mar 23, 2004 | 08:01 PM
fergy016's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">maybe stiffer than the Special Edition GC's, but you can get springs for GC's that are alot stiffer than what comes w/ the S2's.
And IMHO the way the GC sleeves mount up to the Koni shocks 0wnz all other sleeve-type coilovers. </TD></TR></TABLE>
I totally agree with patrick on this topic. gc's are worth every penny. I don't believe the springs/struts no matter what combo are the only thing you should do to the car to remove body roll. When I changed mine out it was like night and day. I love my set-up.
Old Mar 24, 2004 | 05:15 AM
rottencorpse's Avatar
koni/gc; go with those for a cheaper setup that is still good
Old Mar 24, 2004 | 08:10 AM
neo1z's Avatar
Default Re: (rottencorpse)
More importantly, what do you plan on doing? Is it going to be tracked, and/or auto'xd alot?
Old Mar 24, 2004 | 08:29 AM
Rory Breaker's Avatar
Default Re: (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">More importantly, what do you plan on doing? Is it going to be tracked, and/or auto'xd alot?</TD></TR></TABLE>
This is the most important question.
IMO, if Im spending $800 on a setup, Im getting full coilovers that were designed as one unit. Unless you want custom rates that no other coils offer, I dont see the point in going GC/Koni.
Old Mar 24, 2004 | 08:31 AM
Alexander's Avatar
Default Re: (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Unless you want custom rates that no other coils offer, I dont see the point in going GC/Koni.</TD></TR></TABLE>
unless you already bought koni shocks with springs and are looking for an "upgrade"
