Will B16A1 Pistons fit in B17A1?
Old Mar 11, 2004 | 02:41 PM
Shanksma's Avatar
Default Will B16A1 Pistons fit in B17A1?
I just got a 93 Integra GSR with the b17a1. Since Im under the impression that the b17 is just a stroked b16 would b16a pistons work properly? Reason being is that I cannot find any good 12:1 pistons made specifly for the b17a1.
Old Mar 11, 2004 | 03:51 PM
nickgmiller04's Avatar
Default Re: Will B16A1 Pistons fit in B17A1? (Shanksma)
im pretty sure they will fit since both have 81mm bore.
somone correct me if im wrong
Old Mar 11, 2004 | 03:55 PM
Colin's Avatar
yes they will fit. you'll have ~10.73:1 compression using standard bore pistons. The p30's are also a great choice for the b17a, and will yeild ~10.94:1 with standard bore and ~11:1 with standard oversize. Neither will need modification to fit. However gsr, itr and ctr pistons will require that you modifiy your stock rods in order for them to fit.
h22a2JZGTE
Feb 2, 2012 04:59 PM
Sajmon_LP
Engine Management and Tuning
Feb 5, 2011 07:07 AM
vin0410
Honda Fit
Feb 7, 2007 10:20 PM
civic_d16y7
Apr 2, 2005 05:08 PM
bluedelsol
Jun 30, 2003 04:46 PM
