ABS distribution block replacement ?
Old Mar 11, 2004 | 02:07 PM
C4DC's Avatar
Default ABS distribution block replacement ?
Hey guys, newbie 1st post here. You guys have a great forum here. My wife's 96 accord is leaking brake fluid from the distribution block area and I was thinking of buying one from the junk yard and replacing the whole assy. Looks very expensive to go to the dealer. The brakes work fine, but the abs resivor is low. Can I just disconnect the lines and unplug the harness and re-install another one, or are there special procedures that need to be followed? Thanks in advance
Old Mar 11, 2004 | 03:12 PM
cyrk007's Avatar
Default Re: ABS distribution block replacement ? (C4DC)
if you dont want to spend too much you can patch the resevoir with a silicon sealant... thats the least exp and will fix it... it may not look like $ but it;ll work
Old Mar 11, 2004 | 06:42 PM
C4DC's Avatar
Default Re: ABS distribution block replacement ? (cyrk007)
I don't think the resivor is leaking, but I can't really tell with it on the car, is it ok to take the resivor off without removing the distribution block?
Nhoc167
Apr 22, 2010 12:42 PM
bonh
Jun 28, 2007 12:15 PM
The-Kid
Nov 28, 2006 06:47 PM
phateless
Aug 16, 2006 11:31 PM
dchi_t
Mar 10, 2003 03:36 AM
