Need advice on why my engine is dying out periodically
Old Mar 11, 2004 | 01:56 PM
dand39's Avatar
Default Need advice on why my engine is dying out periodically
Can anyone give me some answers/advice?
-Sometimes my car has trouble turning over, it'll keep churning, but it doesn't turn. If I wait a while, it eventually turns. BUT...
-Sometimes when my car does turn over, right away the idle starts dropping real fast, until my car dies out. It holds after a couple tries/patience. Sometimes this problem doesn't even happen, but more often it does.
-It's not fuel pump, fuel relay switch, intake manifold. Took it to a shop to get everthing check, they said they couldn't find anything wrong.
-No check engine lights or ecu codes flash.
Anyone know what's going on? Please post with some advice on how to fix this.
This is my 91 Civic Hatch, b16
Old Mar 11, 2004 | 01:58 PM
Rtype16's Avatar
Default Re: Need advice on why my engine is dying out periodically (dand39)
Wiggle on the wires at the ECU and see if it dies.
Old Mar 11, 2004 | 02:48 PM
tegmech's Avatar
check the tps sensor wires on the tb. play around with the wires by jiggling them around and see if it dies then.
Old Mar 11, 2004 | 04:31 PM
dand39's Avatar
Ok, I'll try both and see if anything happens. Though, my car doesn't die out during 1/4 mile runs, so I don't think it'll be a loose connection or something of that sort.
TimKennard
Jan 2, 2011 10:04 AM
vteckills40r
Mar 12, 2010 04:00 PM
leem23vtec
Aug 13, 2009 10:39 PM
dand39
Mar 12, 2004 02:26 PM
