HELP:Piece of spark plug wire stuck around spark plug
i bought cheap @SS accel plug wires before reviewing them and now a the black peice from the tip of the plug wire is stuck around the spark plug and its impossible to get out.
please help
please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback »</TD></TR><TR><TD CLASS="quote">i bought cheap @SS accel plug wires before reviewing them and now a the black peice from the tip of the plug wire is stuck around the spark plug and its impossible to get out.
please help
A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?
please help
</TD></TR></TABLE>A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?
the tip around the end of the plug wire came off and is stuck on the spark plug, needle nose pliers are too short
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?</TD></TR></TABLE>
With all honesty, throw the spark plug away. They cost a buck or 2 and you will end up buying new plug wires anyway... So it's not worth it..
fs
fs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback »</TD></TR><TR><TD CLASS="quote">the tip around the end of the plug wire came off and is stuck on the spark plug, needle nose pliers are too short
They sell some long *** needle nose pliers, or maybe you can borrow some. Can you still fit the socket over the plug to take the plug out?
</TD></TR></TABLE>They sell some long *** needle nose pliers, or maybe you can borrow some. Can you still fit the socket over the plug to take the plug out?
the black rubber from the plug wire is stuck on the spark plug so no deep socket will fit over it
I dont know man, maybe put some glue on the end of the wire and stick it down in there. Maybe when it dries, you can get it off the plug. There has to be an easier way.
i thought about that, but it would prolly still pull right off with force
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">I dont know man, maybe put some glue on the end of the wire and stick it down in there. Maybe when it dries, you can get it off the plug. There has to be an easier way. </TD></TR></TABLE>
i hate my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">I dont know man, maybe put some glue on the end of the wire and stick it down in there. Maybe when it dries, you can get it off the plug. There has to be an easier way. </TD></TR></TABLE>i hate my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch »</TD></TR><TR><TD CLASS="quote">Can we just point and laugh? Hahaha
lol just use long needle nose pliars. i hope you dont have to take the head off lol. i had a similar problem when my adaptor for my compression tester got stuck in the spark plug hole took me like 2 hours to figure it out.
</TD></TR></TABLE>lol just use long needle nose pliars. i hope you dont have to take the head off lol. i had a similar problem when my adaptor for my compression tester got stuck in the spark plug hole took me like 2 hours to figure it out.
http://www.hondaautomotiveparts.com
Or you can also try the classifieds section, people take off their OEM wires for aftermarket ones all the time.
thanks
i know HAMP is good, have ordered from there before
but where on the site are plug wires?
im having a similar situation, but you didnt post a picture so i can compare, take a look maybe someone on here can help me out,
heres my sparkplug, it looks nothing like the rest, i can see further down, so you said you put superglue? superglue on what>? the socket? and let it sit and try so u can just yank it out?
Long thin flathead screwdriver and/or super long thin pair of needle nose pliers. I've done it like that plenty of times with multiple engines. Coat hanger will also work as well.
