optional sideskirts clips question
Old Mar 11, 2004 | 12:23 PM
lak8's Avatar
Default optional sideskirts clips question
I bought used oem optional sideskirts not to long ago but it didnt come with no hardware. Do the oem stock sideskirt clips work with the oem optional sideskirts? or do i have to buy new clips
Old Mar 11, 2004 | 12:27 PM
DeadLock23's Avatar
Default Re: optional sideskirts clips question (lak8)
they should use all the same mouting point as the stock sides I think....
look at the mouting points of the sides, are they the same as the OEM ones....
and the if they look like they are just take off the stock one and see how it fits up, I think it should be the same.....
Old Mar 11, 2004 | 12:39 PM
lak8's Avatar
Default Re: optional sideskirts clips question (DeadLock23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadLock23 &raquo;</TD></TR><TR><TD CLASS="quote">they should use all the same mouting point as the stock sides I think....
yea ill probably do that but its so cold out side right now hehe i was just wondering if some one knew
Old Mar 11, 2004 | 02:34 PM
sys3rror's Avatar
the OEM optional kit side skirts use the same clips as the OEM skirts. i'm 100% sure since i have them on my car.
here's an install tip for you to make it easier. have the clips put back onto the body of the car and then slide the OEM optional kit side skirt on. it's a lot easier when the clips are already on the car. this way you just line up the side skirt and push it towards the rear to "lock" it into place.
i have the entire OEM kit install instructions uploaded here in full size included the template for the rear pieces
http://www.pbase.com/jw___systems/oe...n_instructions
Old Mar 11, 2004 | 02:46 PM
VTECorona's Avatar
Default Re: (sys3rror)
It's actually easier to lock them into the side skirts and then just snap it into the car. I think you have the right idea just the other way around.
Old Mar 11, 2004 | 04:45 PM
lak8's Avatar
ahh thats alot for your help guys, i also go tthe rear lips so im sure those intructions will help out alot
spintboy
Feb 27, 2008 08:56 AM
BlueStar
Dec 25, 2007 02:39 PM
BG-Teg
Feb 1, 2007 06:05 AM
foam
Mar 31, 2006 07:47 PM
RedTegLS
Mar 17, 2004 03:09 PM
