Will A gsr Header fit on a LS ??
Old Mar 11, 2004 | 11:39 AM
integranator's Avatar
Default Will A gsr Header fit on a LS ??
I recently took off my turbo system, and don't have my old header, but my friend has one off his GSR. I am going to be making a testpipe anyways, just seeing if the mounting points will be any different?
Old Mar 11, 2004 | 11:41 AM
frost_0ne's Avatar
Default Re: Will A gsr Header fit on a LS ?? (integranator)
yes it will
SuzukaBlueAP2's Avatar
94-99 GS-R. Nope.
Old Mar 11, 2004 | 11:42 AM
timmy8151's Avatar
Since, you're going to be putting in a testpipe, any 94-01 Integra header would work. However, if you were using a stock cat, only a 00-01 GSR header would work.
Default Re: Will A gsr Header fit on a LS ?? (frost_0ne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frost_0ne &raquo;</TD></TR><TR><TD CLASS="quote">yes it will</TD></TR></TABLE>
No it won't. The length of the 94-99 GS-R downpipe is different than the LS/RS/GS
Old Mar 11, 2004 | 11:43 AM
timmy8151's Avatar
Default Re: Will A gsr Header fit on a LS ?? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">94-99 GS-R. Nope.</TD></TR></TABLE>
That's assuming he's using a stock cat. But since he's going to be putting in a test pipe, he could cut it to make it fit.
Old Mar 11, 2004 | 11:46 AM
JLange's Avatar
Default Re: Will A gsr Header fit on a LS ?? (timmy8151)
it will bolt up to your block, your gonna just need to mod the test pipe to make it fit
Old Mar 11, 2004 | 11:47 AM
greekspeed's Avatar
if ur using a stock cat the only other header that would fit with eht e stock exauhst/cat is an ITR header.
___EDIT__
since ur making a test pipe it doesnt matter what b-series header you use...ALL b-series headers will bolt up to any b-series head. the only difference of the headers is the length of the DP because different cars that have different b-series motors have different length cats.
Old Mar 11, 2004 | 02:31 PM
Cloud's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Since, you're going to be putting in a testpipe, any 94-01 Integra header would work. However, if you were using a stock cat, only a 00-01 GSR header would work. </TD></TR></TABLE>
Would there be any performance advantage over the stock LS header?
Old Mar 11, 2004 | 02:35 PM
timmy8151's Avatar
Default Re: Will A gsr Header fit on a LS ?? (Cloud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cloud &raquo;</TD></TR><TR><TD CLASS="quote">
Would there be any performance advantage over the stock LS header?</TD></TR></TABLE>
Nope, LS and GSR OEM headers are the same.
Old Mar 11, 2004 | 02:49 PM
EL Vap133's Avatar
This should help: https://honda-tech.com/zerothread?id=388071
Old Mar 11, 2004 | 10:09 PM
xplanetearth420x's Avatar
Default Re: Will A gsr Header fit on a LS ?? (EL Vap133)
i dunno there is not o2 sensor on the gsr header u might run into some trouble
Old Mar 12, 2004 | 09:10 AM
wreckedmyteg's Avatar
Actually, the GSR header is better because has a tubular downpipe. The LS header has a cast downpipe.
I swapped a GSR header into my B20 LS and I noticed a slight difference.
You need to use a GSR cat with the GSR header because the O2 sensor bolts into the cat, VS the header on the LS part.
SOOO...if you use a GSR header, you'll need to weld a bung for the O2 sensor into your test pipe.
The LS and GSR cats are the same length, but the GSR header is about 3 inches shorter.
Old Mar 12, 2004 | 09:22 AM
slomob18b's Avatar
Default Re: Will A gsr Header fit on a LS ?? (greekspeed)
[QUOTE=greekspeed]if ur using a stock cat the only other header that would fit with eht e stock exauhst/cat is an ITR header.
QUOTE]
A usdm itr header won't fit a 94-99 GSR. 00-01 GSR, 94-01 LS, and 97-01 ITR exhaust manifolds are interchangeable.
Old Mar 12, 2004 | 01:06 PM
12secDC's Avatar
Default Re: Will A gsr Header fit on a LS ?? (slomob18b)
yes it will............but it will raise your compression and jack your engine up instantly due to the fact that your putting a vtec head on a none vtec head. Right now I'm telling not to do it until you built your bottom end first.
You''ll be sorry
Old Mar 12, 2004 | 02:27 PM
Honda Hick's Avatar
Default Re: Will A gsr Header fit on a LS ?? (12secDC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secDC &raquo;</TD></TR><TR><TD CLASS="quote">yes it will............but it will raise your compression and jack your engine up instantly due to the fact that your putting a vtec head on a none vtec head. Right now I'm telling not to do it until you built your bottom end first.
You''ll be sorry</TD></TR></TABLE>
WTF are you talking about? HEADER NOT HEAD
Old Mar 12, 2004 | 05:48 PM
greekspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">
hmmmm.. i never heard of that
learn somthing new every day
Old Mar 12, 2004 | 07:00 PM
cougar10ag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">
A usdm itr header won't fit a 94-99 GSR. 00-01 GSR, 94-01 LS, and 97-01 ITR exhaust manifolds are interchangeable.</TD></TR></TABLE>
learn somthing new every day[/QUOTE]
don't listen to him. ok guys like said before. the 94-99 GS-R header a pipe is SHORTER than the other gen 3 integras. therefore. if using STOCK B-PIPES and CATS it WILL NOT fit. but if you are gonna build a testpipe, bend your own b-pipe. thne all b series exhaust headers are interchangable. only difference is the b16 is shorter than the b18's so if you used one for a b16 on another b series the runners would be really close the oil pan and you would need to heat-wrap it. i dunno about the other engine deck height differences tho.
Old Mar 21, 2004 | 10:23 PM
Default Re: Will A gsr Header fit on a LS ?? (cougar10ag)
yes u justy ave to cover the o2 sensor
hamburgler
Jan 13, 2006 08:41 AM
drpepper
Oct 14, 2005 07:00 PM
JDM_EK_808
Oct 6, 2005 10:33 PM
DsBananas94LS
Aug 8, 2004 05:48 PM
Aaron M
Aug 30, 2003 11:26 AM
