Koni yellow quick question
Old Mar 11, 2004 | 10:22 AM
JFG Kevin's Avatar
Default Koni yellow quick question
Is it easy to set the height of the perch?
Old Mar 11, 2004 | 10:24 AM
Solracer's Avatar
Default Re: Koni yellow quick question (aznstyler119)
Yes
Old Mar 11, 2004 | 10:26 AM
purplegsr's Avatar
Default Re: Koni yellow quick question (Solracer)
As long as the shock is off of the car, yes.
Old Mar 11, 2004 | 10:54 AM
Creep's Avatar
Default Re: Koni yellow quick question (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">As long as the shock is off of the car, yes.</TD></TR></TABLE>
In comparison to a coilover setup no it is not.
Old Mar 11, 2004 | 11:00 AM
Boofster's Avatar
Default Re: Koni yellow quick question (Creep)
If you have a spring that is not compressed (i.e. GC's) then you can change it by just lifting the car. Just need some small nose pliers.
I've done it. Why? If you have GC's you want to keep the point of contact as close to the bottom of the spring as you can so you might want to adjust the perch when you change heights.
99hondacura
Suspension & Brakes
11
Jul 7, 2008 09:13 PM
mikeycivic
Suspension & Brakes
Apr 3, 2007 07:29 AM
.I.Need.Money.
Suspension & Brakes
31
Feb 1, 2007 09:24 PM
Cory man
Suspension & Brakes
Mar 8, 2005 01:13 PM
DarKStaR5
Feb 3, 2005 06:25 PM
