cam gear degrees???
Old Mar 11, 2004 | 07:32 AM
donnjuan2point2's Avatar
Default cam gear degrees???
i have searched this and found no answer. my skunk 2 cam gears say 1 mark = 2 degree crank, does this mean that 1 mark = 2 degrees in reference to cam timing, also by advancing the cam timing is that also advancing ignition timing. sorry if ur tired of this topic but any answers are appreciated!
Old Mar 11, 2004 | 08:55 AM
Rtype16's Avatar
Default Re: cam gear degrees??? (donnjuan2point2)
The cam rotate at half the speed as the crank. Meaning for every one degree you are turning on the cam gear it will be two degrees at the crank. Ignore that saying it is useful info if you don't know that info, but it confuses the hell out of people. When people say two degrees advanced they are refering to the actual marks on the cam gear. Two degrees at the cam. No one refers to the crank when tuning cam gears. Also if the cam gear you are adjusting is driving the dist. than yes it will affect your ignition timing.
Old Mar 11, 2004 | 06:56 PM
doublejz's Avatar
Default Re: cam gear degrees??? (Rtype16)
take it to a dyno for the best outcome when tuning
Old Mar 11, 2004 | 07:10 PM
krazie1's Avatar
BANNED
Default Re: cam gear degrees??? (doublejz)
yep yep dyno bro
if it helps u
i got mine one degree on intake and -1 on exhaust
stock b16a cams
so go with that
nothing can happen just a bit hp
unless u build up or something which still ain't **** really
Old Mar 11, 2004 | 08:29 PM
Crisgo's Avatar
Default Re: cam gear degrees??? (krazie1)
I had thought of a similiar question about adjusting cam gears. Just to make sure I understand and anyone else who may read this understands is, one mark advance/retard on the cam gear is in actuality is two degrees at the crank. This info may not serve as useful info unless you adjust the intake cam gear since the distributor timing will alter. Now my question is if all timing marks are lined up, timing light shows that the distributor is set to 15 degrees. If you retard your intake cam one mark on the cam gear (which is two degrees at the crank) is your timing now slightly retarded back to 13 degrees at the distributor? Meaning also that the distributor may need to be advanced again, or no since the purpose of the cam gear adjustment was on a dyno and the actual tuning was done and hp gained. Sorry if I'm really lost or confused anyone. Maybe I should post this in a tuning forum...cheers
Old Mar 11, 2004 | 08:52 PM
eyeamvic's Avatar
Once you change the intake cam, you need to do your timing. You do not have to have the cam gears at stock (0, 0) in order to do the timing.
Old Apr 19, 2004 | 10:34 PM
trooper0641's Avatar
Default Re: (eyeamvic)
so should i do a 1 mark to the + or the -?
Old Apr 20, 2004 | 11:20 AM
Red D Dragon's Avatar
I have my cam gears set at 5 intake -4 exhaust. I gained 22.7 whp and 23.1 lbft in the mid range
95gsr@530
Feb 7, 2015 09:24 AM
eg6madness
Jun 9, 2009 07:54 AM
sleeperb16a
Sep 24, 2007 08:12 AM
ActiveAero
Jan 22, 2003 09:45 PM
Black96Cobra
Oct 28, 2001 11:06 PM
