Will this ECU work?
Old Mar 11, 2004 | 06:52 AM
accordguy95's Avatar
Default Will this ECU work?
I am putting in a manual transmission in my 95 accord, and I understand that the ECU is different than an auto...
The problem I am having is no one has an ECU for manual 95.
But, the question is: Can I use a manual ECU out of a 96 for my year?
Cause I did find one of them...
And if not, does anyone have one available?
Old Mar 11, 2004 | 07:05 AM
CD8's Avatar
CD8
Default Re: Will this ECU work? (accordguy95)
i think in order to use the 96 you need to convert the car to obd2.
Old Mar 11, 2004 | 07:27 AM
Default Re: Will this ECU work? (CD8)
what does that involve?
Old Mar 11, 2004 | 07:33 AM
Legendaryyaj's Avatar
look for a 94, there should be plenty for 94-95 years. STAY away from OBD2 if ya got OBD1(which is what u are).
Old Mar 11, 2004 | 07:59 AM
patastinky's Avatar
Default Re: Will this ECU work? (Legendaryyaj)
yeah what he said keep it obdI, there is no point in going w/ a 96-97 obdII ecu when ur shizzle is obdI
Old Mar 11, 2004 | 08:20 AM
I am totally fine with that, in fact I expected that...
Does anyone know where I can find one for cheap?
Ebay is screwing me and has none on there...
Old Mar 11, 2004 | 08:47 AM
raceACCORDingly's Avatar
with the auto to manual swap ive read there is a way to wire up the auto ecu so that it thinks that its always in gear, but im not quite sure how to do it.
i was wondering if there would be any downside to running a p28 ecu on a f22 since p28's are much more abundant?
Old Mar 11, 2004 | 10:10 AM
Default Re: (raceACCORDingly)
Does anyone out there know how to wire the auto ECU to make it think it is a manual? Details please!!
Old Mar 11, 2004 | 10:15 AM
InjectedPerformance's Avatar
We sell parts.
Default Re: (accordguy95)
I have a 94 vtec p0a 5speed ecu for sale.
Old Mar 11, 2004 | 01:26 PM
Default Re: (primo8998)
mine is non-vtec
Old Mar 12, 2004 | 07:01 AM
Anyone on that wiring for the auto ecu to work???
Old Mar 12, 2004 | 06:19 PM
tdr-'s Avatar
i have one for sale for but its for a 94'
Old Mar 12, 2004 | 06:52 PM
nuc79's Avatar
Default Re: (tdr-)
Have you tried using a 5spd with the auto ECU yet? If it's like the civic (WHICH IT'S NOT, because the Accords have a separate TCM to control tranny functions-- at least the 90-93 does, and all integra autos do too), then the worst that will happen is that the car will run fine but have a code 19.
The code 19 appears on the auto P28s after swapping to 5spd because it's looking for a tranny solenoids that aren't there. Good thing is that the P28 auto ecu can be changed to a 5spd by pulling 2 resistors and adding a jumper. I've never seen a procedure for accords.
The BEST case scenario is that there will be no check-engine codes, and the car will run exactly as it should.
If I were you, the ECU would be the last thing I'd do. It's the easiest part, plus you don't get greasy. And an irrelevent CEL won't keep you from driving the car in the meantime. My brother's been driving his Civic with a code 19 for 8 months...
Old Mar 13, 2004 | 01:58 AM
http://www.extremeredline.net/...iring
ive read of some accords running p28 ecu's so i dont see why it cant be done on an accord. just i dont know if theres any downsides to running the p28 on an f22
Modified by raceACCORDingly at 11:08 AM 3/13/2004
highrev98civic
10
May 13, 2008 02:51 PM
bonez817
Jan 22, 2007 10:44 PM
Street Sweeperz
Dec 16, 2006 09:03 AM
cas95
Dec 12, 2006 02:19 PM
q8delsol
Nov 3, 2006 07:15 AM
