A JDM Type R Header will fit a B16 right?
Old Mar 10, 2004 | 10:29 PM
PDXHatchback's Avatar
Default A JDM Type R Header will fit a B16 right?
Like the topic says, i have the 4-1 Type R JDM header and was wanting to make sure it fits the B16 head.(for an 01 Si)
Old Mar 10, 2004 | 10:41 PM
EmsRoleModel's Avatar
Default Re: A JDM Type R Header will fit a B16 right? (PDXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">Like the topic says, i have the 4-1 Type R JDM header and was wanting to make sure it fits the B16 head.(for an 01 Si)</TD></TR></TABLE>
I don't believe it does. The b18c has bigger exhaust ports than the b16.. you may be able to mount it, but that doesn't mean that it will perform correctly.
Correct me if I am wrong.
Old Mar 10, 2004 | 10:44 PM
Default Re: A JDM Type R Header will fit a B16 right? (EmsRoleModel)
if so, bummer!
Old Mar 10, 2004 | 10:48 PM
EkREV's Avatar
New User
it will fit...
Old Mar 10, 2004 | 11:17 PM
Default Re: A JDM Type R Header will fit a B16 right? (EkREV)
without losing out on any power?
Old Mar 10, 2004 | 11:49 PM
EkREV's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">without losing out on any power?</TD></TR></TABLE>
it will make power...
courtesy of importreview.com
Old Mar 10, 2004 | 11:54 PM
Mar_DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EmsRoleModel &raquo;</TD></TR><TR><TD CLASS="quote">
Correct me if I am wrong.</TD></TR></TABLE>
the exhaust ports arent that much bigger than the B16's. it wouldnt negatively affect performance unless the header flanges were smaller than the exhaust ports anyway.
Old Mar 11, 2004 | 01:22 AM
Formula 1's Avatar
Default Re: A JDM Type R Header will fit a B16 right? (Mar_EK)
that dyno says nothing about an ITR header it says JDM and 4-1 thats it that could be a mugen header fit for a b16
anyways it should fit
Old Mar 11, 2004 | 01:38 AM
rocket256's Avatar
Default Re: A JDM Type R Header will fit a B16 right? (SikCivic)
The head on an ITR is a B16 the has been upgraded right. Its just the block is a B18
Old Mar 11, 2004 | 01:39 AM
Formula 1's Avatar
Default Re: A JDM Type R Header will fit a B16 right? (rocket256)
correct
Old Mar 11, 2004 | 02:54 AM
RICE POLICE SIP's Avatar
the type r header will fit and work it's just a little longer then the b16 header because of the block height...
Old Mar 12, 2004 | 04:21 AM
Lil Corb's Avatar
sorry for hijacking. So will the collector be the same length as it would on a USDM header? or would you have to get a custom size testpipe/hiflo cat?
this is for a b16
thanks
Old Mar 12, 2004 | 04:44 AM
b16 matt's Avatar
Default Re: (Lil Corb)
It will fit. I have 2 friend with this mod.
Old Mar 12, 2004 | 04:49 AM
Lil Corb's Avatar
so it'll fit perfect like a usdm header?
thanks
Old Mar 12, 2004 | 06:27 AM
AllMoToRB18c's Avatar
it will fit the exhaust ports fine but its gonna hang a lil lower because of deck height.....thats about it
Old Mar 12, 2004 | 08:27 AM
NA PRO's Avatar
It will fit. The header will hang extra low because the deck height on a B18 is a little taller so, I wouldnt suggest having your car too low or you will easily ding the down pipe section of the header, unless you have a skid plate.
Old Mar 12, 2004 | 08:43 AM
Lil Corb's Avatar
thanks guys
Old Mar 12, 2004 | 08:46 AM
Mr Boston's Avatar
Yes it will fit on the exhaust ports but it has a 2.5 diameter collector on the jdm itr header.. Not sure if you already know that
Old Mar 12, 2004 | 08:48 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb &raquo;</TD></TR><TR><TD CLASS="quote">so it'll fit perfect like a usdm header?
thanks</TD></TR></TABLE>
the JDM 4-&gt;1 header will bolt onto the head fine, but it wont bolt to ur stock cat. the jdm header has a 2.5" collector. you're gonna need a new cat/test pipe or a new flange welded onto your stock car
ProEater's Avatar
Default Re: (Clicky Pow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clicky Pow &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will fit but it has a 2.5 diameter collector.. Not sure if you already know that</TD></TR></TABLE>
agreed. but am i the only one who saw that he said it was for an 01 si?
Old Mar 12, 2004 | 09:23 AM
eg360B's Avatar
01 Si? They stoped making b16 Si in Us in 2000 buddy.
Old Mar 12, 2004 | 09:25 AM
976's Avatar
976
New User
Default Re: A JDM Type R Header will fit a B16 right? (DreK9)
I'm running a JDM 4-1 on my 1st gen b16 right now... I wouldn't recommend anything else! Performance wise...
Old Mar 12, 2004 | 09:34 AM
Lil Corb's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
the JDM 4-&gt;1 header will bolt onto the head fine, but it wont bolt to ur stock cat. the jdm header has a 2.5" collector. you're gonna need a new cat/test pipe or a new flange welded onto your stock car</TD></TR></TABLE>
so the collector ends right where the usdm collector ends correct? the JDM 4-1 is not longer right?
thanks
Old Mar 12, 2004 | 10:15 AM
SD_EM1's Avatar
i have it. matched it with a carsound 2.5" cat
Old Mar 12, 2004 | 12:44 PM
976's Avatar
976
New User
Default Re: A JDM Type R Header will fit a B16 right? (mr. miyagi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. miyagi &raquo;</TD></TR><TR><TD CLASS="quote">i have it. matched it with a carsound 2.5" cat</TD></TR></TABLE>
Yup, same here. Plus my custom exhaust with ES oval it sounds quite beefy...
