Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Steel for sunroof plug kit
Old Mar 10, 2004 | 09:10 PM
Tyson's Avatar
Default Steel for sunroof plug kit
i want to plug the sunroof on my CRX. couple questions, what gauge steel or thickness should i use that matches the rest of the roof? the hardware store had a choice of "weldable" steel and "galvanized" steel. galvanized was cheaper, should i use that? im not going to weld it, im just going to attach it using L brackets. i hope to paint it, will it make a difference? also this link seems to say galvanized is different in standard thickness than regular steel. true?
http://www.unc.edu/~rowlett/un....html
thanks.
Old Mar 10, 2004 | 09:13 PM
Steve91's Avatar
Default Re: Steel for sunroof plug kit (Tyson)
I would go with something around .032" to .040". If I remember correctly, I did my in .040". I would not get galvanized if your going to paint it.
Old Mar 10, 2004 | 09:29 PM
Sobe_Death's Avatar
i have found that galvanized sheet metal is a b**ch to work with. stick with non galvanized and save some headaches
Old Mar 10, 2004 | 10:00 PM
travis's Avatar
Default Re: (Sobe_Death)
Check your IM. I'm pretty sure that the OEM body panels are 22 gauge.
Wazup
Nov 23, 2007 05:42 PM
turbotime
Aug 11, 2006 07:19 PM
Doogie Howser
Nov 8, 2002 07:00 AM
Integra_Boi
Aug 5, 2002 10:39 PM
.J.
May 2, 2002 04:23 PM
