The Definitive CTR Piston / B16 Thread
Old Mar 10, 2004 | 08:31 PM
Pentaxis's Avatar
Default The Definitive CTR Piston / B16 Thread
I've seen various answers to this question after slinking in the shadows and searching all over this site, but now I think it is time that the truth comes out!
In order to run CTR pistons with the stock pr3 rods in a b16a1, what does one need to do?
This may seem like an easy question, but some say the rods need milled. Others say bolt the damn things in, slap the head on, and have a nice day!
What is the right answer?
Thanks!
Old Mar 10, 2004 | 09:34 PM
EKhatch's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (Pentaxis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pentaxis &raquo;</TD></TR><TR><TD CLASS="quote">some say the rods need milled. </TD></TR></TABLE>
These people are correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pentaxis &raquo;</TD></TR><TR><TD CLASS="quote">. Others say bolt the damn things in, slap the head on, and have a nice day!
These people are wrong.
Old Mar 19, 2004 | 10:27 AM
Pentaxis's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (EKhatch)
If that is the case, then what part of the rod needs the trimming?
Old Mar 19, 2004 | 11:27 AM
chad's Avatar
Moderator
the neck area where the wrist pins slides through....
Old Mar 19, 2004 | 11:39 AM
EKhatch's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">the neck area where the wrist pins slides through....
Yes 1mm off each side so that is effectively the same width of a GSR rod. 18mm if I remember correctly but don't quote me on that.
Old Mar 19, 2004 | 11:43 AM
Beave0101's Avatar
Old Mar 19, 2004 | 01:22 PM
Pentaxis's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (Beave0101)
Thanks guys!
Old Mar 20, 2004 | 04:11 AM
likaciv's Avatar
How bout springing the extra cash and just getting a set of gsr or itr rods, wouldnt that be a little less screwing around?
Old Mar 20, 2004 | 06:17 AM
Benny Hinn's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (likaciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likaciv &raquo;</TD></TR><TR><TD CLASS="quote">How bout springing the extra cash and just getting a set of gsr or itr rods, wouldnt that be a little less screwing around?</TD></TR></TABLE>
You can't do that in a B16 block.
Rods are too long, and they are not wide enough at the "base" or big end for the crank/rod journal for a b16 crank.
Old Mar 23, 2004 | 04:22 AM
likaciv's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (Benny Hinn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benny Hinn &raquo;</TD></TR><TR><TD CLASS="quote">
Rods are too long, and they are not wide enough at the "base" or big end for the crank/rod journal for a b16 crank.</TD></TR></TABLE>
Dammit, why does this have to be so complicated
Are there any other stock honda rods (obviously besides the gsr and itr's) that are stronger than the b16's that will fit the b16 with ctr pistons? I really dont want to go all forged, that can get way too expensive.
Old Mar 23, 2004 | 09:13 AM
arw321's Avatar
I believe it may be easier for your machine shop to machine the pistons instead of the rods. That's what mine did.
Old Mar 23, 2004 | 06:34 PM
likaciv's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">I believe it may be easier for your machine shop to machine the pistons instead of the rods. That's what mine did.
what part of the piston? Wouldnt the rods be easier?
Old Mar 30, 2004 | 07:54 AM
Pentaxis's Avatar
And I remember finding an extremely good thread regarding the compression that different motors would have utilizing CTR slugs... anybody have a link to that?
Old Mar 30, 2004 | 09:13 AM
arw321's Avatar
what part of the piston? Wouldnt the rods be easier?</TD></TR></TABLE>
The inner part of the piston where the rod fits into. Either method will work, personally I feel better about having a little more material on my rods and a little less material on my pistons.
Old Mar 30, 2004 | 11:36 AM
likaciv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pentaxis &raquo;</TD></TR><TR><TD CLASS="quote">And I remember finding an extremely good thread regarding the compression that different motors would have utilizing CTR slugs... anybody have a link to that?</TD></TR></TABLE>
http://www.c-speedracing.com/h...c.php
Here ya go little fella
Old Mar 30, 2004 | 11:39 AM
WAFFLES's Avatar
that calculator is not accurate!
Old Mar 30, 2004 | 11:55 AM
Jays91DXhatch's Avatar
Default Re: The Definitive CTR Piston / B16 Thread (WAFFLES)
http://www.bojangs.com/calculator/
I hear this one is better?
11:1 with stock 3 layer head gasket
11.2:1 with 2 layer
11.6:1 with 1 layer
I may go this route myself instead of LS/Vtec...just cuz I have the motor already etc.
slowcrxsib16
16
Oct 1, 2007 01:14 PM
gutted-dx
Nov 18, 2005 05:37 AM
Digga4
13
Jan 20, 2005 03:13 PM
S10RALLYRACER
Aug 24, 2004 08:49 AM
95gsr
May 17, 2003 07:52 AM
