JDM 96 ITR ecu same as USDM ITR?
Old Mar 10, 2004 | 06:10 PM
mugenracer's Avatar
Default JDM 96 ITR ecu same as USDM ITR?
I'm going to fit a VAFC to my 96Spec JDM ITR and need to know if the ECU pinouts for the USDM ITR are the same. I have the diagram for the 00 USDM ITR P73 ecu, is it different to earlier 97-99 ITR ECUs or are the pin locations all the same. While i'm at it i was going to fit an A/F gauge also but i see that USDM ITRs have primary and secondary O2 sensor pins, but the JDM ITR only has a single O2 sensor, so i guess it is the primary in this case? And is it safe to assume if the pin locations are different that the O2 sensor wire at the ECu will be the thick white one on the third plug out?
Old Mar 10, 2004 | 08:03 PM
ITR#132's Avatar
You want the ecu pinouts from a 96-98.
Unless you want to read the Air Fuel ratio after it gets cleaned up by the Cat, You should always tap the Primary O2
4NLINE UNLIMITED
Mar 2, 2011 12:32 PM
kay_animation
Sep 8, 2010 12:42 PM
96_GsR_BlownEngine
May 10, 2007 05:45 PM
96_GsR_BlownEngine
Jul 24, 2004 04:03 PM
_unknown_
May 30, 2002 09:01 PM
