Spark Plugs for Turbo LS
Old Mar 10, 2004 | 04:22 PM
JDubya's Avatar
Default Spark Plugs for Turbo LS
I searched and found that BCPRe7's are what most people say to use. But I just checked my Helms and it says for NGK to use ZFR5F. Which one is better?
Old Mar 10, 2004 | 04:28 PM
-iLLuZioN-B18C1's Avatar
Default Re: Spark Plugs for Turbo LS (ALL MOTOR LS)
why not ngk bkr7e?
JDubya's Avatar
Default Re: Spark Plugs for Turbo LS (-iLLuZioN-B18C1)
I think those are for VTEC
Old Mar 10, 2004 | 05:04 PM
Haberdasher's Avatar
use the BCPR7E-11
the helms tells you what to run for a stock motor. With a turbo you need a colder plug, the 7 is colder than the 5.
Old Mar 10, 2004 | 05:07 PM
mildly.interesting's Avatar
6097 stock number....
Old Mar 10, 2004 | 05:29 PM
JDubya's Avatar
Default Re: Spark Plugs for Turbo LS (Haberdasher)
yea I know that the 5 and 7 refer to the plug coldness. I was wondering about the first few letters...
and what did you mean by "6097 stock number..." ?
Old Mar 10, 2004 | 05:47 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">why not ngk bkr7e?</TD></TR></TABLE>
That's what I run, although I don't have an LS.
Old Mar 10, 2004 | 05:50 PM
Blackack26's Avatar
Default Re: Spark Plugs for Turbo LS (5thgencivic)
I use the BKR7E's on my b18a and they seem to be doing fine...
Old Mar 11, 2004 | 05:38 AM
JDubya's Avatar
Default Re: Spark Plugs for Turbo LS (Blackack26)
anyone else? And for around 10psi on an LS, should I go 1 step, or 2 steps colder? I'm leaning towards 2....
Old Mar 11, 2004 | 07:51 AM
Rah Rah's Avatar
I use BKR7E's
Old Mar 11, 2004 | 07:59 AM
Teg4e's Avatar
Default Re: Spark Plugs for Turbo LS (Rah Rah)
My tuner recommended an 8 cold plug for my simple turbo car, but everyone on here will recommend a 7. Both have worked fine for me.
Old Mar 11, 2004 | 09:28 AM
Turbo E's Avatar
BKR7E.
Old Mar 13, 2004 | 03:09 PM
JDubya's Avatar
Default Re: (Turbo E 604)
keep it comin...
Old Mar 13, 2004 | 05:55 PM
Short Round's Avatar
Default Re: (ALL MOTOR LS)
12.5 psi - 14psi daily stock b18b longblock 300whp/270tq on 12.5 psi i used bcpr7e-11's gapped at .35 no problems whatsoever, stock ignition, 93 octane, dist timing @ 15 deg
Old Mar 16, 2004 | 08:57 AM
JDubya's Avatar
Default Re: (Short Round)
I guess I'll go with the BCPR's. Should I get the V-Power or the regular? and where's the best place online to get them from?
Old Mar 16, 2004 | 06:41 PM
JDubya's Avatar
Old Mar 17, 2004 | 09:42 AM
sydag5's Avatar
What are most of you all gapping them at? I'm gapping mine at .032 right now. Just seeing what everyone else is doing
Old Mar 21, 2004 | 04:32 PM
JDubya's Avatar
Default Re: (sydag5)
should I get the V-powers, or the regulars? BCPR or BKR?
Old Mar 21, 2004 | 08:23 PM
it really doesnt make all that much of a difference unless ur making huge power
Old Mar 22, 2004 | 04:24 AM
JDubya's Avatar
Oh ok, what's the cheapest place online to get them from?
Old Mar 22, 2004 | 04:36 AM
Ri5e's Avatar
I run stock LS plugs and they're great!
Old Mar 22, 2004 | 06:24 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haberdasher &raquo;</TD></TR><TR><TD CLASS="quote">use the BCPR7E-11
the helms tells you what to run for a stock motor. With a turbo you need a colder plug, the 7 is colder than the 5.</TD></TR></TABLE>
Yes, but dont get the -11's. The -11's come gapped to a .044, just get the bcpr7es which comes witha .035 gap I believe, so thats less stress on the tip when gapping to .028-.030.
NGK part number 3330.
Old Mar 22, 2004 | 08:02 AM
Default Re: Spark Plugs for Turbo LS (PrecisionH23a)
AH YAH, I WAS RUNNING .35 GAP
Old Mar 22, 2004 | 08:06 AM
SIK IN DA HED's Avatar
New User
get the bcpr7es11 plugs
Old Mar 22, 2004 | 03:23 PM
HybridHatchC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Short Round &raquo;</TD></TR><TR><TD CLASS="quote">it really doesnt make all that much of a difference unless ur making huge power</TD></TR></TABLE>
if theres a difference he wants the better plugs believe me
