summer oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunkDaddyFresh »</TD></TR><TR><TD CLASS="quote">guinness draught</TD></TR></TABLE>
P.S. Newcastle Brown Ale as well ...
gets on my nerves when people recomend to use a fully synthetic oil in a car... if you dont run that from the start then put it in a car with over 30,000 miles or even over 50,000 or 100,000 you WILL have leaks... but do what you want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubbedtodeath »</TD></TR><TR><TD CLASS="quote">gets on my nerves when people recomend to use a fully synthetic oil in a car... if you dont run that from the start then put it in a car with over 30,000 miles or even over 50,000 or 100,000 you WILL have leaks... but do what you want
This isn't necessarily true with today's synthetics. When synthetics were 100% PAO, there were some leaking problems. However, new synthetic formulas have addressed the seal leaks. If you are leaking with synthetics, the problem may not be the oil, but the fact that you may have worn seals and gaskets.
</TD></TR></TABLE>This isn't necessarily true with today's synthetics. When synthetics were 100% PAO, there were some leaking problems. However, new synthetic formulas have addressed the seal leaks. If you are leaking with synthetics, the problem may not be the oil, but the fact that you may have worn seals and gaskets.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sergei01 »</TD></TR><TR><TD CLASS="quote">but i thought that the owners manual said that u should use 5w30 conventional dino oil. why do u guys use 10w40?</TD></TR></TABLE>
in the summer it is warmer, can use a thicker oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGIDYBOB »</TD></TR><TR><TD CLASS="quote">i've been using 10w30 all this time. would it make a difference if i use 5w30 like it says on the oil cap?</TD></TR></TABLE>
Just stick with 10W-30. There's really no need to change weights.
If you live some that is warm year round then 10w-30 is just fine. But for those of us that live in places that get cold in the winter, using 5w-30 is something to consider. It may not be that big of a difference, but it gives me a little piece of mind starting my car in the winter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">go with a 10w-30 motor oil such as chevron supreme or chevron high mileage.</TD></TR></TABLE>
I'm currently using 10W-30 Chevron Supreme after reading excellent reviews and UOA's on Bob's forum. At $0.69/qt, its cheap and a very good oil.
