Need your advice plz
Old Mar 10, 2004 | 03:18 PM
Rev-Olution's Avatar
Default Need your advice plz
Hey all, im getting ready to install my H&R's on my eg tomarrow in auto tech and was wondering if anyone has a good DIY or anything i should look out for while putting it on...I'm going to be doing fronts then backs since i only have 1hr 30mins each period to do this....Any help will be appreciated..
*SEARCHED*
Old Mar 10, 2004 | 04:23 PM
TeamNextGenChris's Avatar
Default Re: Need your advice plz (Rev-Olution)
best i can tell you is to get a shop manual.if you can't figure out how to do it,maybe you should get somebody more experienced to do it or help you.
chris
Old Mar 10, 2004 | 06:13 PM
Default Re: Need your advice plz (TeamNextGenChris)
Im pretty sure i can do it, just wondering if anyone had some helpful advice or tips that might help me get it done a little quicker...
Old Mar 10, 2004 | 06:32 PM
Discosteak's Avatar
your struts are going to be hard to get off i suggest you buy new ones before you put on the springs. you may end up doing what i did and cut them off
Old Mar 10, 2004 | 06:37 PM
Y2KEBPSI's Avatar
Default Re: Need your advice plz (BADEG6)
I would soak all the bolts with WD40 or some kind of lubricant and let it soak in overnight. It will make them come out a little easier if you get the rust broke down a little bit. When you get in there and start you will see how to do it. I have taken mine off and put back in, in less than an hour.
Good luck !
DaveF
Welding / Fabrication
26
Jul 12, 2007 09:19 AM
seer
Oct 9, 2006 06:51 AM
Wazup
May 21, 2006 05:15 PM
CivicSiRracer69
Oct 2, 2003 06:46 PM
direct_connect
Oct 16, 2002 10:56 AM
