what's next
Old Mar 10, 2004 | 02:29 PM
JDM4DR.GSR's Avatar
Default what's next
i have a 00' 4 door GSR with a cai, cat-back exhaust, and v-tec controller......exterior wise i am lowered with ground control coilovers, and have black 15 inch rota slipstreams.....what do you suggest that i do next performance wise??????????????????????????
Old Mar 10, 2004 | 02:31 PM
jdmintegls's Avatar
get some headers....intake manifold... cams..etc.. it all depends on what you wanna do? go n/a or turbo?...for suspesion get some good shocks like koni yellows or kyb agxs
Old Mar 10, 2004 | 02:35 PM
JDM4DR.GSR's Avatar
Default Re: (jdmintegls)
definately going n/a i am looking into a header and a manifold as of last month what else do you suggest
Old Mar 10, 2004 | 02:36 PM
swanny's Avatar
Default Re: (JDM4DR.GSR)
How much you got? We could spend all of your money if you want us to. What is this going to be used for? HP Goal?
Old Mar 10, 2004 | 02:38 PM
JDM4DR.GSR's Avatar
Default Re: (xy swany)
i am going to use this for street and strip, i am just looking for opinions, hp goal not really worried about that
Old Mar 10, 2004 | 02:39 PM
kNOwLedGeDA9
Guest
Posts: n/a
The first task to making a strong B-series engine is to rid ot of all restrictions. You have an intake, and an exhaust. You still need an intake manifold (Skunk2 is the only choice but you need to get a different ECU that is not programmed for dual butterfly intake manifold), a header (I recommend the DC JDM 4-1 w/ 2.5" collector), and a less restrictive catalytic converter or straight pipe. This takes out all of your flow restrictions. It also seems as you need some aftermarket shocks ( I prefer the Tokico Illumina or the KYB AGX) Good LUCK!
Old Mar 10, 2004 | 05:33 PM
JDM4DR.GSR's Avatar
Default Re: (kNOwLedGeDA9)
i am have been looking into manifolds and headers these are things i plan on doing ...thank you for the info
explicit_del_sol
May 20, 2008 10:10 PM
iheartjayDem
Suspension & Brakes
Jul 11, 2006 09:56 AM
Syndacate
27
Feb 23, 2006 06:57 PM
danteisme
Feb 26, 2004 04:28 PM
