removing the back seats
I know that back seats are a bitch sometimes, did you try shoving your hand in there and feeling around for some bolts?
What do you mean by making a difference with the airbag sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAFA »</TD></TR><TR><TD CLASS="quote">as in if i disconnect the sensor, will the airbag light stay on?</TD></TR></TABLE>
i dont know but most likely it would cause its disconnected... maybe if you pull the fuse itll go away, but safety first i rather have it connected man...
if you pull the srs sensor from the front seat, it will trigger the srs light.
the airbag would still work tho'.
pulling the fuse wouldn't do a thing, just take out the negative terminal, disconect the sensor, get all the work done and pull it back on.
you'll need to reset the srs computer after you put the seat back.
pretty simple trick.
if you have a coupe, pull off the carpet in the back of the seat, just pull down the seat and pull off those plugs, you'll see some bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAFA »</TD></TR><TR><TD CLASS="quote">anyone ever put civic si seats in a six gen accord?</TD></TR></TABLE>
Front or rear?
Front or rear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAFA »</TD></TR><TR><TD CLASS="quote">will they fit and where would you buy them? the dealer?</TD></TR></TABLE>
they will not bolt on without minor fabrication with the mounting bracket.
nor the civic seat will.
notice that civic and s2k seats are much lower than accord seat, you'll have a hard time seeing if you are short.
s2k seat cost around 2k in dealer last time i check, or used 700 buck, not bad at all for leather seats huh?
If you looking for other cheaper alternative, look for those recaro made SI(EP3) seats, suede material
https://honda-tech.com/zerothread?id=804981
check that link out!
Modified by iam7head at 4:18 PM 3/19/2004
Do you mean the top or bottom part of the seat?
To remove the bottom, there's one bolt in the crevice, sort of by the right seat buckles (the right one of the two sets in the crevice), then just lightly pull up on the front (clips).
