starting problems...
Old Mar 10, 2004 | 02:10 PM
pootie.teng's Avatar
Default starting problems...
yo i just dropped my fully built ls/vtec into my ek and guess what. the sucker won't start. it cranks and stuff but nothing. but if i pull the evap purge hose off it will start cause its sucking in air from the hole then i get this bad idle like i gots some wildass cams on it but there only ctr cams. i get the code from the ecu and its code 14, iacv. so i guess somethings wrong with it thats why it won't start cause its not getting any air unless i pull a hose off of the manifold to give it air. i gave the iacv 12v to see if it works, and it clicks. so i'm lost and been trying like hell to work it out. i'm guessing its my ecu because i'm just using a stock p28 to start the motor. can that be the problem or something else. anything will help...
Old Mar 17, 2004 | 01:50 PM
EKGirl's Avatar
Default Re: starting problems... (teckno_geek)
bump
AgentJam
Feb 7, 2004 08:04 AM
turbo sol
Jan 3, 2004 05:57 AM
RenoRacing
15
Oct 14, 2002 06:58 PM
RenoRacing
Oct 9, 2002 07:55 PM
