PLEASE HELP, valve adj nut fell into oil flow hole!!!
Old Mar 10, 2004 | 01:54 PM
bluecb7's Avatar
Default PLEASE HELP, valve adj nut fell into oil flow hole!!!
While doing some maitenance on my head, i was screwing on the LAST valve adj. nut, when it slipped and fell into this hole: (Engine is H22A)
All I heard was it bouncing around and then drop onto something metal, AHHHHHHH!!!!!!! I was done with everything, goddamn it!!!!!!!
Did this nut fall into the oil pan???? I need to know, PLEASE HELP!!!
Modified by bluecb7 at 5:54 PM 3/14/2004
Old Mar 10, 2004 | 02:09 PM
AzG35's Avatar
Default Re: PLEASE HELP, valve adj nut fell into oil flow hole!!! (bluecb7)
It should be in the oil pan. that is where those journals go.
Old Mar 10, 2004 | 02:10 PM
EKhatch's Avatar
Hopefully it made it all the way to the oil pan and if your lucky will tumble it's way out if you drain the oil.
Most likely time to take the pan off.
Old Mar 10, 2004 | 03:03 PM
ranta18's Avatar
Default Re: PLEASE HELP, valve adj nut fell into oil flow hole!!! (EKhatch)
The same thing happend to me. I found it sitting in the windage tray. Take that off and you should see it.
Old Mar 10, 2004 | 03:32 PM
asubennett's Avatar
Default Re: PLEASE HELP, valve adj nut fell into oil flow hole!!! (ranta18)
It will amost for sure drop into the oil pan and past the windage tray. Next oil change stick a magnet pen in their and fish around. You should come up with it. THat way you'll save yourself an oil pan gasket.
Old Mar 10, 2004 | 03:38 PM
BluLude's Avatar
Default Re: PLEASE HELP, valve adj nut fell into oil flow hole!!! (asubennett)
make sure you take it out before you start your car or go driving around with it...it probably wont be very good if your crank hits that nut randomnly
Old Mar 10, 2004 | 03:56 PM
asubennett's Avatar
Default Re: PLEASE HELP, valve adj nut fell into oil flow hole!!! (BluLude)
crank won't hit it. It would be a act of god if the crank hit it.
Old Mar 10, 2004 | 04:24 PM
BluLude's Avatar
well you dont wanna give him the chance to jack you over do you...bahahaha lol
Modified by BluLude at 8:44 PM 3/10/2004
Old Mar 13, 2004 | 04:37 PM
asubennett's Avatar
LOL that is very true! I think he has a kinder heart than that though. Never know our mufflers are pretty annoying he might be wanting to rid uus of these cars now so he won't have to have them in heaven for us.
Old Mar 14, 2004 | 04:51 PM
bluecb7's Avatar
IT LIVES!!!!!
With the exception of an exhaust leak from a broken gasket, my engine is running perfectly, no ticking from LMA's sticking, and it purrs baby, yeah!!!!
One thing that scared me is that I found an extra valve adj nut in the oil pan . So now I have one extra valve adj nut. and a new oil pan gasket. The old one was a bitch to get off, it was caked on there like nothing I've ever seen. Had to work on it for like an hour But it's done and everything is good. Thanks for your guy's help.
hondaboy4life
Sep 29, 2006 08:01 AM
bluecb7
Mar 28, 2004 03:46 AM
B20-T
Feb 24, 2003 10:44 PM
