So I have this new door actuator
Old Mar 10, 2004 | 01:16 PM
alexus's Avatar
Default So I have this new door actuator
I removed the old one last saturday but my problem is the new one with the little hole. The little hole that when you connect it to the power door locks it moves left to right. Where does that connect to? When I took the old one out I can't really see inside. Does anyone have a pic? Thanks.
Old Mar 11, 2004 | 11:13 AM
alexus's Avatar
Default Re: So I have this new door actuator (alexus)
bump
Old Mar 11, 2004 | 06:45 PM
skiier's Avatar
Look for the rod coming down to the lock assembly from the "key" actuator. (NOT the inside push/pull door ****.) The end of the rod sits on a cam that moves the lock assembly lock/unlock lever. The "little hole" you refer to on the lock actuator is actually a rod from the electric actuator. The lock actuator performs the same function as the "key" actuator so it must be connected to the same cam to lock/unlock the door. Make sure the little hole is mechanically connected on the cam, the same as the key actuator rod. When you attempted to install the 3 screws holding the lock actuator to the lock assembly didn't you notice that the holes didn't line up very easily? It doesn't line up because the thing isn't going together right. You have to tip the lock actuator - in relation to the lock assembly -so the little hole goes over the cam whilst pushing in and lining up the screw holes. You will know when it is in place.
craiger02v6
Mar 26, 2015 04:45 PM
pdidnotkno
Sep 7, 2014 06:24 PM
mutiny93
Jun 29, 2011 11:20 AM
DC_craze
Dec 27, 2006 05:04 PM
AxisAccord
Aug 1, 2005 05:41 PM
