possible noob ? about vtec
when vtec engages, is it the intake side that opens up first? like, the "primaries" are the intake side, then the "secondaries" are the exhaust side? is that right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Train »</TD></TR><TR><TD CLASS="quote">when vtec engages, is it the intake side that opens up first? like, the "primaries" are the intake side, then the "secondaries" are the exhaust side? is that right?</TD></TR></TABLE>
Check out this article on Team-Integra. It'll explain a lot better than I can. If you don't already have an account on TI, get one.
uh oh....here come the FLAMERS!!!!
im asuming you have a gsr..
there are smaller longer "runners" in your intake manifold = high velocity at low rpms. there are also butterfly valves that open bigger shorter "runners" = high volume at high rpms.
there is nothing on your exhaust side except your header
primaries or secondaries does not apply to valves
it applies to the way the gsr intake manifold is
designed.
with a shor runner or long runner control by a butterfly this benefits how the air
flows into the head.
designed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">primaries or secondaries does not apply to valves
designed.
Should add that that's not linked to VTEC direclty. It happens at a different RPM...different system
designed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro »</TD></TR><TR><TD CLASS="quote">
Check out this article on Team-Integra. It'll explain a lot better than I can. If you don't already have an account on TI, get one.</TD></TR></TABLE>
ahh. good article. i'm now a little bit smarter.
thanks
thanks
Hapa88
Apr 22, 2004 09:20 AM
