Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Front ITR swaybar, worth it?
Old Mar 10, 2004 | 06:46 AM
Micro's Avatar
Default Front ITR swaybar, worth it?
I have a GSR front subframe sitting in my garage, that i might be installing before the NY/NJ region SCCA auto-X season begins this year. I was wondering two things...
1) front swaybar (gsr) is it worth installing the front GSR subframe to get the added handling properties of a front sway bar?
2) I also have a front ITR swaybar sitting around... should i install it into the GSR subframe if i'm going that route?
3) If i do plan on putting in the ITR front bar, what parts need replacement from the GSR bar? (e.i. d-brackets, bushings etc. ?)
Fro reference: ITR 22mm swaybar already installed, along with Apex-i coilovers.
Old Mar 10, 2004 | 06:51 AM
JeffS's Avatar
Default Re: Front ITR swaybar, worth it? (Micro)
Maybe I'm misunderstanding you, but I thought the front GSR and ITR bars are the same.
Old Mar 10, 2004 | 07:04 AM
Micro's Avatar
Default Re: Front ITR swaybar, worth it? (JeffS)
i'm wondering that too.
Old Mar 10, 2004 | 07:14 AM
DsITR's Avatar
Yes they are the same diameter
https://honda-tech.com/zerothread?id=379726
I'm wondering why you would want the front bar at all.. unless your car is dramatically oversteering now, or has some serious body roll, wouldn't you just run the larger rear bar?
Old Mar 10, 2004 | 07:23 AM
Micro's Avatar
Default Re: Front ITR swaybar, worth it? (DsR)
i alreadty have the rear 22mm ITR... i was wondering if the front would help out with auto-xing, and some track time
Old Mar 10, 2004 | 07:39 AM
.RJ's Avatar
.RJ
I would leave the front sway bar in.
Old Mar 10, 2004 | 07:54 AM
Dan GSR's Avatar
Default Re: Front ITR swaybar, worth it? (.RJ)
yes front gsr and itr is both 24mm
Old Mar 10, 2004 | 08:17 AM
AdamITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I would leave the front sway bar in.</TD></TR></TABLE>
I agree. I use the stock front bar and the mugen rear bar.
Old Mar 10, 2004 | 08:18 AM
Micro's Avatar
thanks .RJ
I think i'll just install it and go fom there. I'm not using a high spring rate, so i'm guessing the front bar will help with some roll issues.
My old Race Rabbit had yellow koni's, 600lb front and 450 rear, no front swaybar, 22mm rear swaybar and it was a killer auto-x setup. I want to make the civic handle just as good.
spog
Jan 9, 2005 04:48 PM
mixmastabob
Nov 29, 2003 09:03 AM
b18bfreak
Mar 3, 2003 11:09 AM
B18C5-EH2
Feb 19, 2002 08:00 AM
