exhaust leak but no exhaust leak?
Old Mar 10, 2004 | 03:52 AM
GDM Z28's Avatar
Default exhaust leak but no exhaust leak?
ok if you rev the engine up slowly theres no leak, but as soon as u nail the pedal hard for a second you hear it. and when i hear the leak i feel air come out of my dumptube. its really freaking weird. does this mean there might be a crack in my dumptube? any help would be apreciated.
Old Mar 10, 2004 | 05:26 AM
GDM Z28's Avatar
Default Re: exhaust leak but no exhaust leak? (civicflnum1)
TTT
Old Mar 10, 2004 | 06:33 AM
Muckman's Avatar
Moderator in Chief
uh maybe your wastgate is opening?
Old Mar 10, 2004 | 11:28 AM
GDM Z28's Avatar
Default Re: exhaust leak but no exhaust leak? (Muckman)
bro i know what a WG opening sounds like. it just started sounding like this the other day. could it be that the dump tube has a crack in it?
Old Mar 10, 2004 | 11:32 AM
Mad Cow's Avatar
I'm not sure exactly what you're describing, are you feeling exhaust coming from the side of the tube, or from the end of the dumptube (assuming you have an open dump tube)?
Old Mar 10, 2004 | 07:02 PM
GDM Z28's Avatar
Default Re: exhaust leak but no exhaust leak? (MadCow)
from the end of the dump tube but it sounds loud as hell like its leaking from somewhere. im gonna have to pull the dump tube out n check for cracks. it just started making this noise a few days ago.
Old Mar 10, 2004 | 08:02 PM
CaptainMorgan's Avatar
If you ran an open dump tube, why does it matter if its leaking. Either way its going to dump gas into the air.
Old Mar 10, 2004 | 08:14 PM
GDM Z28's Avatar
Default Re: exhaust leak but no exhaust leak? (doubler)
cause its loud as ****, and i dont care about the leak i just wana know why its making this loud *** noise all of a sudden
Old Mar 11, 2004 | 08:42 AM
I think the reason when you rev the engine slowing and there is nothing, is because there is still vaccum holding the WG close. When you push on it hard the engine goes into 0 vaccum, so your WG will open up. But your spring should hold it close. HEre are some question, do you have a spring in, how much psi is the spring rated, and have you try checking the WG itself and see if the WG is on the manifold tight.
Old Mar 11, 2004 | 12:31 PM
GDM Z28's Avatar
the WG has a 3 lb spring and yes the WG is on the manifold tight. but why would it start making this noise recently
Old Mar 11, 2004 | 02:23 PM
did you use the stock tial gasket they sent you. I heard they are really bad. If i were you i would check on that, I would bet thats, causing the leak.
ohemgiii
Oct 2, 2015 08:38 PM
Dannyboy21
Sep 9, 2008 10:13 AM
serious
May 5, 2004 08:58 AM
JunIntegra
Jan 8, 2004 04:57 AM
tc
May 1, 2003 10:00 AM
