Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How many of you are using a front sway-bar in your ITA/H4 CRX?
Old Mar 10, 2004 | 01:08 AM
travis's Avatar
Default How many of you are using a front sway-bar in your ITA/H4 CRX?
I have been exchanging information with a handful of people on this board regarding various setups for these cars. While certain opinions seem to be pretty pervasive, I have seen a wide range of opinions regarding optimal front/rear roll stiffness. Some people prefer to increase the size of the rear bar and keep the OEM front, some increase the rear and remove the front, and others just remove the front and use the OEM rear. And this seems to be done within a narrow range of spring rates that are similar to mine (400-500F/500-700R).
I drove all last year on OEM sway bars front and rear. This season I have removed the front bar and have continued to use the OEM rear. I have yet to manipulate the rear sway bar thickness, but this is next.
I would just like to get an idea for who's running what in this specific application. Thanks for any input.
Old Mar 10, 2004 | 03:50 AM
Geezer's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (travis)
I'm on the 500f/700r springs, with a 22mm ST bar in back and no bar in front. Started off last year (first year racing) with the OEM front bar and the ST rear bar at its softest setting. With a bit of experience in the car, I tried disconnecting the front bar, and found that I liked the looser rear end, so I dumped it alltogether. Eventually went to the middle setting on the rear bar and was happy with that at year's end. On advice of others who do well in CRXs, I set the shocks (Koni) soft in front and medium in back. Seemed to work well, so never messed with them. Be aware that last year I was solidly mid-pack, so take my advice with as many grains of NaCl as desired.
Of course last year the engine and drivetrain were pretty stock. Over the winter I picked up LSD, FD, and a more healthy motor, so I may have to play some more with the suspension this year.
Old Mar 10, 2004 | 08:16 PM
travis's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (Geezer)
So you're now running the 7/8ths rear on the middle setting and no front bar. Do you feel like the car is predictable at turn-in? Do you trail brake still? I haven't yet decided if I like the front bar out, but I'm willing to adapt to anything that's faster since it's not like I'm set in my ways. Anyone else?
Old Mar 10, 2004 | 08:31 PM
Fastist12's Avatar
500/700 springs
Tokico 5 way
22mm bars front and rear [ middle setting on rear bar]
works great
CRX-Si
SCCA/ICSCC
#12 ITA
Old Mar 10, 2004 | 09:16 PM
Steve91's Avatar
450F/700R
Stock sways at both ends
Old Mar 11, 2004 | 03:51 AM
Geezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">So you're now running the 7/8ths rear on the middle setting and no front bar. Do you feel like the car is predictable at turn-in? Do you trail brake still? I haven't yet decided if I like the front bar out, but I'm willing to adapt to anything that's faster since it's not like I'm set in my ways. Anyone else?</TD></TR></TABLE>
Turn-in seems predictable. Doesn't plow and not darty at all. Front toe is now +1/8" and rear at zero BTW. Tried +1/4" in the front and turn-in was a bit quicker, but the thing was so darty under braking I had to back off to +1/8".
If I do my part, I can trail brake in and the rear will rotate what seems the proper amount to me, with the car set up about right for throttle when it's time to get back into it. Folks tell me that as I get more experience, I'll likely want to loosen up the rear end a bit more. We'll see.
Now if I could just find somebody with an acknowledged well set-up car to let me drive it, or get two or three top CRX drivers to try mine out and provide feedback , I'd probably know more.
Old Mar 11, 2004 | 04:43 AM
CRX Lee's Avatar
I typically ran no front bar and a bigger, preferably adjustable rear bar and normally 400f 600r springs and was very happy with it on several cars for years. After I got rid of the car, I talked to someone in the industry who suggested that I test using the least bit of front bar I could find (meaning an OE HF bar) to help keep the nose flatter in low speed, tight corners. Turn 7 at Mid-Ohio, the right hander at the bottom of the Esses, comes to mind.
I will likely build another of these cars soon and will likely try it.
Old Mar 11, 2004 | 09:55 AM
Balled S2K's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (CRX Lee)
500F/700R, ST rear bar set as stiff as she'll go and no front bar.
Removing it knocked over a second off my Summit times from the previous session.
Old Mar 13, 2004 | 09:56 PM
travis's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (Balled S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Balled S2K &raquo;</TD></TR><TR><TD CLASS="quote">500F/700R, ST rear bar set as stiff as she'll go and no front bar.
1 second with no other changes to the car? That would be a pretty significant data point if that's the case.
CRX Lee, I too have heard about the use of the HF front bar. I guess it's something of a compromise between the OEM Si bar and no bar at all. So you were running no front bar at 400# up front, eh? I'm wondering if there's a point at which the front spring rate affects the ability to run with/without the front bar.
I know that there are no right answers, but I'm always surprised at how varied ITA CRX competitors are when it comes to this. I think the majority fall on the side of "no bar," however. Is that just because the rest of them haven't gotten around to trying it yet?
-travis, who is currently running no front bar and can't, for the life of him, decide what he thinks of it.
Old Mar 15, 2004 | 11:21 AM
Balled S2K's Avatar
Yup...Ran saturday...took it off Sunday AM at 6am and my first session out was a consistent one second faster on that particular track. YMMV.
Old Mar 15, 2004 | 01:04 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Balled S2K &raquo;</TD></TR><TR><TD CLASS="quote">Yup...Ran saturday...took it off Sunday AM at 6am and my first session out was a consistent one second faster on that particular track. YMMV.</TD></TR></TABLE>
Well, I can't argue with that. Did you feel one full second faster? As I learn this car I realize all over again that what feels fast isn't always fast. I'll be adding the ST rear bar shortly so I can do some back to back testing for myself, but I still think it's reasonable to adjust my driving to fit what is actually fastest for this car. Hell, I already have to learn the whole damn car anyway
Old Mar 15, 2004 | 01:15 PM
Balled S2K's Avatar
Oh yeah...I felt a difference. The main reason I stiffened up the rear as much as I did was because I was getting so much push out of the front. Although a little twitchy in sharp transitions now, the car feels very neutral must everywhere else.
It feels very natural to me, and very similar to my S2000 did (if that's possible).
Old Mar 15, 2004 | 03:38 PM
Hracer's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">others just remove the front and use the OEM rear. And this seems to be done within a narrow range of spring rates that are similar to mine (400-500F/500-700R).</TD></TR></TABLE>
We tried with and without the front and rear bars and settled for running the rear oem bar with the front bar disconnected on 500f 700r springs. But it's going to be different for everyone, since shock valving, spring rates, tires (and pressures), tracks, driver preference, etc. always vary. Try back to back sessions with it on and with it off with your current setup and see how you like it most.
Old Mar 15, 2004 | 06:51 PM
Catch 22's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (Hracer)
91 Civic
450/650
ST Rear
No front.
Car feels great. I think leaving off the front bar also helps put some power down on the inside font exiting the corner. You don't have the bar levering the wheel up.
Old Mar 16, 2004 | 12:21 PM
MightyMouseTech's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (Crosser)
A Honda with a front bar? Haven't seen one of those in a while........
Old Mar 16, 2004 | 01:36 PM
travis's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">A Honda with a front bar? Haven't seen one of those in a while........ </TD></TR></TABLE>
That's the impression I'm getting, with similar responses on IT.com. I guess this isn't as big of a split as I originally thought.
Catch 22,
You bring up a good point. You are using an LSD, correct?
Old Mar 16, 2004 | 03:58 PM
Ron Carroll's Avatar
Has anyone tried running a 2nd gen ITA/H4 Integra with no front bar?
Old Mar 16, 2004 | 04:58 PM
Catch 22's Avatar
You bring up a good point. You are using an LSD, correct?</TD></TR></TABLE>
Of course. One of those fake OPM units .
Old Mar 16, 2004 | 05:03 PM
Want2race's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (itaintegra52)
I tried.
It wasnt working for me.
The car was constantly correcting itself when i didnt want it to!
The feel without it is better 10 fold!
Old Mar 16, 2004 | 09:28 PM
civicrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itaintegra52 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone tried running a 2nd gen ITA/H4 Integra with no front bar? </TD></TR></TABLE>
Interesting thought, Ron. The HC weight for that car is set @ 2480. Bit more weight than the HC weight for the H4 CRX @ 2175.
Tried disconnecting my front bar @ Sears (Infineon). It felt good but didn't net me lower lap times. This is on my H4 Civic coupe.
Old Mar 16, 2004 | 09:43 PM
johng's Avatar
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (civicrr)
Come on Mike.... take the front bar off and throw it as far as you can.
Old Mar 17, 2004 | 06:25 AM
Default Re: How many of you are using a front sway-bar in your ITA/H4 CRX? (johng)
Well I guess the only way to know for sure is to try it, I never ran a front bar on my 1st gen crx when I was racing it and liked how it felt but we are talking a lot heavier car. I have 2 SCCA races to play with it before my first H/C race.
spaazm
Apr 13, 2014 10:17 PM
xXSanderXx
Feb 16, 2012 09:24 PM
kess
Apr 28, 2005 04:49 PM
deviant1
Acura TSX
Dec 1, 2004 11:46 PM
