What RPM to shift at on stock tach
Old Mar 10, 2004 | 12:41 AM
Luchini's Avatar
Default What RPM to shift at on stock tach
From reading the boards it looks like the stock tach is off by 400 RPM. So if the redline is 7400 should I wait until the tach needle reads 7800 to shift? I usually shift just past redline like at 7500.
Old Mar 10, 2004 | 12:58 AM
bad-monkey's Avatar
Default Re: What RPM to shift at on stock tach (Luchini)
i shift at 8K on the tach, more or less. i'm not ever paying much attention to it when i'm close to redline anyway, there's probably something like a cone or a rumblestrip i ought to be looking at.
Old Mar 10, 2004 | 10:01 AM
Behan's Avatar
Default Re: What RPM to shift at on stock tach (bad-monkey)
if i shift at redline using my stock tach i am right at 7k to 7100 rpms via the vafc. which is roughly where the h22's power peaks.
Old Mar 10, 2004 | 11:26 AM
HondaH22A's Avatar
I shift exactly at the redline on a stock tach. Once in a while I passed the redline.
Old Mar 10, 2004 | 03:14 PM
Monkey Fing a Coconut's Avatar
just expirament as to where you have to shift to stay in vtec in the next gear, that way you dont go higher than you need to since ur not at peak power during that time....
Old Mar 10, 2004 | 03:34 PM
93vtec's Avatar
i shift at around 7900.. results.. ran a 14.5@95.7 with iceman cai, 2.5 piping stock muffler.. 2.2 60ft.
Old Mar 11, 2004 | 12:19 AM
Luchini's Avatar
Default Re: (93vtec)
7900? seems a bit high for an h22a. but i guessed it worked out for u
enphotography
Sep 24, 2006 09:05 AM
SFlCrx
Sep 12, 2006 03:46 PM
SleepnCiViC
Dec 8, 2003 07:34 AM
HondaLife2126
Mar 5, 2003 09:32 PM
bustaman0763
May 29, 2002 11:37 PM
