Building my JDM GSR!
Old Mar 9, 2004 | 11:37 PM
Hybrid CRX's Avatar
New User
Default Building my JDM GSR!
ok so i got a sohc swap to take its place..... i wanna midly build my jdm gsr motor, its going in my 94 si hatchback. i was wondering what would be needed to get some good numbers, i know pistons, cams, intake manifold, clutch, flywheel, cam gears, header, exuast. what kinda pistons shold i get? should i sell thegsr head, and get a b16a head? i need some help deciding! thanks
Old Mar 10, 2004 | 12:27 AM
DVS_EF's Avatar
Default Re: Building my JDM GSR! (Hybrid CRX)
go with the JDM ITR's... (p73-00's)... and keep the gsR head
92 civic VX B18c's Avatar
HT Black Ops
Good luck! I'm doing the same thing just little by little..My next couple of upgrades are, Sending the P72 head i just bought off a friend to get ported and polished and milled .020...Hopefully that gets me over 11:1, and a larger throttle body 67-64mm and hondata...
After looking at a GSR dyno tuned with hondata that made about 15 less whp then I do, but had 20 more whp @ 5,000rpms then my car..All with similar mods sold me on hondata..
I can't afford the down time at this time of the year so i can't do a piston upgrade..But I would love to do an 84.5mm piston upgrade to get extra displacement...
Old Mar 10, 2004 | 09:29 PM
Hybrid CRX's Avatar
New User
so i should go with some JDM ITR pistons? where could i buy some of these? and if installed what would my compression ratio be? what abou tthe head? ITR cams, and skunk 2 manifold with plastic gasket.
Old Mar 10, 2004 | 10:24 PM
HT Black Ops
Default Re: (Hybrid CRX)
the JDM CTR pistons will give you a better C/R right around 12:1
Old Mar 10, 2004 | 10:57 PM
eyeamvic's Avatar
Default Re: (92 civic VX B18c)
How much do you have to work with? I would go with either JDM ITR pistons or even some b16a pistons. Would also be good to go with some cams to match. Depends how much you're willing to spend and what your goals on your setup are.
Old Mar 11, 2004 | 08:08 AM
Hybrid CRX's Avatar
New User
im not all that rich so im goin with a mild build up. Also with the CTR pistons my CR would be really high, is that safe for daily driving? 12;1 is really high
Old Mar 11, 2004 | 10:28 AM
marieT1GRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid CRX &raquo;</TD></TR><TR><TD CLASS="quote">im not all that rich so im goin with a mild build up. Also with the CTR pistons my CR would be really high, is that safe for daily driving? 12;1 is really high</TD></TR></TABLE>not tuned, daily driver get it tuned
Old Mar 11, 2004 | 10:34 AM
Team 4's Avatar
Default Re: (ThatOneGirl)
I used ITR (US spec) in my GSR, and noticed quite a bit of difference.
Recommended:
ARP rod bolts
deck head
Valvetrain upgrade
Cams
Port the GSR maifold and get new butterfly plates made up (cheap)
Good header (Even the modded Edelbrock will work well)
Hondata (or a minimum of VAFC)
Keep the GSR head for the smaller chambers!
Old Mar 11, 2004 | 02:28 PM
Hybrid CRX's Avatar
New User
whatever i get it will be tuned, also i am getting the AEBS manifold, and plastic gasket from hondata. Still deciding on what pistons i want.
Hybrid CRX's Avatar
New User
should my rods be fine, btw?
Old Mar 11, 2004 | 05:08 PM
Team 4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid CRX &raquo;</TD></TR><TR><TD CLASS="quote">should my rods be fine, btw?</TD></TR></TABLE>
They should be fine. The weak link is the rod bolts, but the ARP's take care of that!
Think about the JDM ITR's if you want more compression, or the USDM's if you want more "room for error". (Bad tank of gas on a road trip.)
Old Mar 11, 2004 | 08:14 PM
Hybrid CRX's Avatar
New User
so basically right now im goin with...
stock jdm gsr rods with ARp rod bolts
CTR or JDM ITR pistons
What head gasket should i get? stock?
probably ITR cams, and valve train
AEBS Intake Manifold with plastic Hondata gasket
intake
JDM 4-1 header
exuast of some sorts
cluth and flywheel
should turn some ok numbers but nothing drastic
Old Mar 11, 2004 | 10:24 PM
Team 4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid CRX &raquo;</TD></TR><TR><TD CLASS="quote">so basically right now im goin with...
intake
JDM 4-1 header
cluth and flywheel
should turn some ok numbers but nothing drastic</TD></TR></TABLE>
Stock headgasket with JDM ITR's will be your best bet.
Check out a bit more serious of a cam setup though.
Old Mar 11, 2004 | 11:08 PM
Hybrid CRX's Avatar
New User
well with the money setup right now itr cams would be the best set-up. further down the road if i get serious i would run some toda spec B's or C's
Old Mar 12, 2004 | 03:07 PM
Team 4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid CRX &raquo;</TD></TR><TR><TD CLASS="quote">well with the money setup right now itr cams would be the best set-up. further down the road if i get serious i would run some toda spec B's or C's</TD></TR></TABLE>
Plan to spend $$$ on the valvetrain too!
Old Mar 13, 2004 | 01:28 PM
Hybrid CRX's Avatar
New User
just found an ok deal for $460 i could get some ITR cams, valve springs, and retainers.
does this sound like a good deal?
mn_babyboy
Nov 22, 2008 10:11 PM
xialbyix
Dec 6, 2007 06:19 PM
bullet647
Jul 15, 2007 09:19 PM
Jdm integra DB8
Jan 25, 2007 12:42 PM
