Ignition timing 95 ls
Old Mar 9, 2004 | 09:04 PM
kerby116's Avatar
Default Ignition timing 95 ls
I have a 95 ls in my civic. I cant figure out why the timing jumps around. I checked my timing belt it is not stretched. i dont have valve tap so i am pretty sure it is not a bent vale i have proper fuel i cant figure it out can someone help.
Old Mar 10, 2004 | 07:07 AM
Dasavior's Avatar
Default Re: Ignition timing 95 ls (kerby116)
don't forget to check your distributor bc the timing could be bumped up or just slightly off by a little, bc if it was move just a little your timing could be off a lot or a little.
good luck
jsweet
Oct 31, 2007 06:19 PM
kerby116
Mar 10, 2004 08:34 PM
rbdynamics
Dec 12, 2001 10:30 PM
