May have to use stock injectors on my setup...Yay or Nay?
Old Mar 9, 2004 | 07:30 PM
Casey's Avatar
Default May have to use stock injectors on my setup...Yay or Nay?
Im 99% done with my new setup, and now my resistor box is going to be late so im wondering if i can use my stock 240 injectors with higher pressure. I am hoping to get it running by fri or sat and dyno saturday. LMK what you think, heres the setup:
jdm gsr 10.9:1 compression(from the valves)
supertech intake valves
RM NAE exaust valves
rlz stage 2 cams
rlz stage 2 headwork
skunk2 IM
ericks 68-66 tb
an-r header
b&m fpr
hondata
im probably going to turn 9100-9200 rpm with this. let me know what you think. As far as power, im guessing right at or a little more than 200 at the wheels. Thanks
Old Mar 9, 2004 | 08:10 PM
Icey112's Avatar
Default Re: May have to use stock injectors on my setup...Yay or Nay? (Casey)
i read that the 240cc will handle around 210-215 hp tops some one on the board had 225 hp and was running stock 240 inj.
Old Mar 9, 2004 | 08:36 PM
b18c-93's Avatar
New User
should be fine
Old Mar 9, 2004 | 08:43 PM
zigs's Avatar
Default Re: May have to use stock injectors on my setup...Yay or Nay? (b18c-93)
According to my hondata mine when running at 98% duty cycle at 8400 RPM's with 190 whp. So I didnt even mess with the cam gears until I get some injectors. I'll more than likely go with RC 370's.
Old Mar 9, 2004 | 09:07 PM
Eddiebx's Avatar
you might be able to get away with stock injectors if you bump up the fuel pressure. on a 200whp h22 i tuned, i was pushing about low to mid 80s duty cycle with the stock 340cc injectors at stock pressure.
Old Mar 9, 2004 | 09:24 PM
b19coupe's Avatar
You will need bigger injectors. You could bump the fuel pressure to help, but I would recommend bigger injectors when you can afford them.
Old Mar 9, 2004 | 11:36 PM
Casey's Avatar
Default Re: May have to use stock injectors on my setup...Yay or Nay? (b19coupe)
ive already got dsm 450s, but my resistor box hasnt been shipped
Old Mar 10, 2004 | 12:12 AM
GOLDBERG's Avatar
go to a junkyard real quick and grab one then
Old Mar 10, 2004 | 04:05 AM
Casey's Avatar
Default Re: May have to use stock injectors on my setup...Yay or Nay? (GOLDBERG)
yeah i think ima yank one off my friends crx
SD1222
May 20, 2006 07:49 PM
stevieteg
Dec 1, 2004 02:09 AM
mafay2
Nov 12, 2004 08:24 AM
Type RS
Dec 25, 2003 08:34 PM
whatVTEC
Jul 11, 2003 08:39 AM
