MILLED HEAD, CAM TIMING???
Old Mar 9, 2004 | 03:48 PM
donnjuan2point2's Avatar
Default MILLED HEAD, CAM TIMING???
OK I REALLY NEED A ANSWER TO THIS I HAVE A 95 JDM H22 WITH A MILLED HEAD AND USING A 1 LAYER HEAD GASKET HOW MANY DEGREES SHOULD I ADVANCE MY CAM TIMING TO BRING IT TO STOCK?? ALOS WHAT ABOUT IGNITION TIMING?? THANX IN ADVANCE 4 UR ANSWERS
Old Mar 9, 2004 | 04:07 PM
87sivtec's Avatar
Default Re: MILLED HEAD, CAM TIMING??? (donnjuan2point2)
You need to be a little more specific. How much was milled off?
Old Mar 10, 2004 | 06:43 AM
Default Re: MILLED HEAD, CAM TIMING??? (87sivtec)
oh sorry 30 thousanths was milled off
Old Mar 10, 2004 | 03:12 PM
ranta18's Avatar
DAM! Thats a lot with the head gasket. Thats like .050" gone now. Its 1 degree for every .012", so you're looking at about 4 degrees on the cams. Just set the ignition with a timing light. 17 degrees is stock. Takes about 2 minutes.
Modified by ranta18 at 2:19 PM 3/11/2004
Old Mar 11, 2004 | 06:43 AM
Default Re: MILLED HEAD, CAM TIMING??? (ranta18)
ur a big help thanxs what would happen if i advance the ignition timing to maybe 19? more power?
Old Mar 11, 2004 | 01:47 PM
ranta18's Avatar
It depends. You could start to detonate. Just watch the graph when you're at the dyno. You should be able to see if it is.
Old Mar 11, 2004 | 01:59 PM
ok thanx
drmix
May 27, 2008 09:25 PM
Cyphear
Nov 22, 2004 03:12 AM
donnjuan2point2
Mar 9, 2004 05:04 PM
Edwin
Jul 17, 2002 05:58 AM
J T*
Jul 2, 2002 04:27 PM
