JDM CF driver side power window switch
Have any one install a JDM CF driver side p/w switch. The USDM switch does not fit the JDM CF cover. Hahaha just found that out. So I have to use the whole thing. It plug right in but the auto window switch does not work. You have to hold it down just like normal for the window to roll down. Have any one have the same problem.
put the controls for your car into CF panel. This is what I did on my SiVTEC since the ITR didn't have the one-touch up/down feature that my window has.
The USDM control switch will not fit the JDM CF cover. I dont know how you got your to fit. Yes the ITR have one touch roll down.
The auto down feature will not work with the driver side window. It will work on lowering the passenger side window with one touch.
That is correct. You can not swap the switch of your USDM and put it on the JDM. The switch ABS molding is different. My one touch on the JDM switch for the passenger does not work either. I think the way its wired into the relay.
The switch only goes to the driver side because of the plug fit right in. The only thing that is not working is the on touch roll down on the passenger side.
so our USDM switch will still fit into the jdm cf panel but the one touch windows roll down will not work?
you guys have got me confused on the driver/passenger side....haha which side?
ok the passenger side is only a panel with one button (power window) rite?
and the driver side panel should go right on top of our switch? please clarify
JDM CF cover will not fit USDM switch if you put the whole JDM switch in the touch will not work.
That is correct, the passenger side only have one button.
...hehehehe
