How do i change my shocks?
Old Mar 9, 2004 | 12:58 PM
blk97lude's Avatar
Default How do i change my shocks?
wats up guys. im trying to change my springs right now.. and right now im having a problem breaking the bolts.. is there a easier way to break the bolts?
i need to know asap...
thanks
bryan
Old Mar 9, 2004 | 01:19 PM
RAB's Avatar
RAB
Default Re: How do i change my shocks? (blk97lude)
couple of different methods for the home based DIY guy.
1.) get a breaker bar.
2.) get some rust busting lubricant.
Old Mar 9, 2004 | 01:47 PM
AndyD's Avatar
Default Re: How do i change my shocks? (RAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">couple of different methods for the home based DIY guy.
JUst helped my friend two days ago change his out. Breaker bar helps A LOT!!
Old Mar 9, 2004 | 03:36 PM
Revi's Avatar
Default Re: How do i change my shocks? (AndyD)
Yes a breaker bar is a must in everybodies tool box. That or a 3' long steel pipe.......crankpulley didnt stand a chance!
Old Mar 9, 2004 | 05:49 PM
speedracer9k's Avatar
the easiest way i've found to break off bolts is take brake fluid and an old tooth brush, and rub the brake fluid on the bolt with the toothbrush. I did this when i changed my header and those bolts were never removed since that car came out in 93 and it worked like a charm, then use a breaker bar..that'll make it a bit easier
Old Mar 9, 2004 | 08:49 PM
NoLipRacen's Avatar
Default Re: How do i change my shocks? (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">Yes a breaker bar is a must in everybodies tool box. That or a 3' long steel pipe.......crankpulley didnt stand a chance!</TD></TR></TABLE>
mines a 6-footer! thats what i need to use to get the spindle nuts off... those bizimnatches are sposed to be torqued to 181ft/lbs!
enrique
Dec 9, 2004 04:29 PM
bonta-kun
Apr 24, 2003 10:48 PM
Zulu888
Apr 5, 2003 02:00 PM
Weston
Aug 7, 2002 03:11 AM
