JDM DC2 headlight questions???
So I just know realized that the U.S. harrness plugs for the head lights do not fit in to the JDM headlight plugs
..So my question is how do you plug them in??? Do I need a certain plug??? do you just hardwire them??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg »</TD></TR><TR><TD CLASS="quote">So I just know realized that the U.S. harrness plugs for the head lights do not fit in to the JDM headlight plugs
</TD></TR></TABLE> second option you listed
..So my question is how do you plug them in??? Do I need a certain plug??? do you just hardwire them?? </TD></TR></TABLE> second option you listed
for my conversion. i used female spade connectors. i also heard you can get the plug its the same plug like the one from your ign. harness that goes into the fuse box. i have not yet to try it . i have to go to the junkyard for the spare plugs.
Carlo
Carlo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">you can use female spade connectors to hook up to the pins on the brown connector on the back of the headlights</TD></TR></TABLE>
is there a particular spade connector where can i get em
i spliced/cut mine and routed them the correct way. it wasnt that hard...there are a grip of diagrams on ht. it literally took like 15 minutes for the entire process. the lowbeam if you have non hid is a direct plug in..take the back of your connector and put it into the one on the headlight.
This place has where everything is on the harness,..and on my old Conversion,..I'm not sure how they(the Body shop) wiried it.
http://tech.wiredspeed.com/jdm_front.asp
ITR.#1446
Aug 27, 2008 10:03 PM
