help screw is stripped on door
Old Mar 9, 2004 | 07:58 AM
VietFoo's Avatar
Default help screw is stripped on door
i was tryin to take off my door panel and the screw that is by the door panel and the lock was in there so tight that i stripped the hell out if it.. what can i do to take it offf and can i get another screw for it at the dealers????
Old Mar 9, 2004 | 08:03 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: help screw is stripped on door (VietFoo)
you can get another screw from the dealer or use another one from somewhere else in your car. may want to try some vice grips.
Old Mar 9, 2004 | 09:31 AM
tooky2's Avatar
you may want to try a small drill bit then try your screw driver again. it will take some tapping to get the screwdriver to bite but it will. same thing happened to me. sucks though, good luck
Old Mar 9, 2004 | 09:43 AM
mr.beeks's Avatar
Default Re: help screw is stripped on door (tooky2)
drill that baby out...
da9pwnsu
Jul 31, 2005 07:08 AM
Bone Stock
Apr 1, 2004 05:02 PM
done
Dec 18, 2002 11:45 AM
PainfulTeg
Aug 3, 2002 05:30 PM
