fmu or vafc for tunning a turbo
Old Mar 9, 2004 | 07:10 AM
DXK Eg's Avatar
Default fmu or vafc for tunning a turbo
which one will work better??? i have dsm 440 cc injectors ??ishould i hack the vafc with the injectors and not use the fmu. i was told that it was not a good ideal to use all three in this set up??new fuel pump or the dtock on with the vafc or the fmu????
Old Mar 9, 2004 | 07:38 AM
white95eg's Avatar
Default Re: fmu or vafc for tunning a turbo (dynasty-x-motorsport)
I would say your best bet is to ditch the FMU and run the AFC hack with the DSM injectors. It is only good for about 10psi, but it's a good start. An upgraded fuel pump is a good idea, but not necessary for this set up. If you decide to upgrade, go with a Walbro 255lph.
Old Mar 9, 2004 | 07:42 AM
b16ahybrid's Avatar
You can do either.
I personally ran the fmu,sfc,and 310cc injectors to get my numbers. It worked good for me.
Which ever you decide they both work.
Old Mar 9, 2004 | 07:58 AM
Griffin@Camtech's Avatar
Default Re: fmu or vafc for tunning a turbo (b16ahybrid)
Personaly I am running a FMU, and VAFC with 440cc RC injectors
works for me
Old Mar 9, 2004 | 09:29 AM
DXK Eg's Avatar
Default Re: fmu or vafc for tunning a turbo (EK2NR)
sounds good i'll try it out and see what works out the best.
thanks for the infor.
sodacan33
May 14, 2004 10:39 PM
egturbo
Nov 19, 2003 11:56 PM
DCbb6
Oct 26, 2003 01:07 AM
TurboTeG4
Jul 4, 2002 04:37 PM
zojirushi
Jan 1, 2002 05:56 PM
