obd2 distributor on obd1 h22 swap
well i have the external coil and i have the the obd distributor. i also have a place racing harness for an obd2 h22into an eg...however i have an obd1 h22. it seesm all i have to do is add a resistor box and switch the injector plugs....but the dist. is wired up diff...would it be ok to jsut run my obd2 distrubutor and teh coil. If not, is there any way i could wire it in somehow...thanks
please let me know asap
better off using the obd1 dizzy...i had the same issues trying to get an obd2 dizy to fire on an obd1 engine......though i was using an obd2 car
