Advan RGs - will they rub?
Searhed with many results by no mention of offset and clearances.
Would 16x7.5, 45mm offset on 225 40 16 fit under stock suspension without ANY modifications to fenders and will it rub on full lock? Thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julow »</TD></TR><TR><TD CLASS="quote">225 is to wide to fit the fenders. 215 is the widest you can go.</TD></TR></TABLE>
yeah a friend of mine out here has the same rim
hes got the 215's on it and is a civic
heres a pic of how low it can go with that size rim/tire combo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">Searhed with many results by no mention of offset and clearances.
Would 16x7.5, 45mm offset on 225 40 16 fit under stock suspension without ANY modifications to fenders and will it rub on full lock? Thx</TD></TR></TABLE>
i think it depends on which 225s, im running azenis 215/45 and mine dont rub at all.
Before I had the suspension done to it it was not rubbing. But now I'm rubbing in the front at full lock and the back is fine. Because the spring rate I'm running is stiff so the front and the back wheels does not hate the body of the car. I have 215/45-16 Azenis on the car. And yes the RG's are 13lbs.
Here is the car before the suspension done to it.
Here is the car after the suspension.
Does it weight 13lbs ea like it says on the tin?
