painting my header
Old Mar 8, 2004 | 09:55 PM
iuseamsoil's Avatar
Default painting my header
how do i go about painting my header? would i powder coat it? and if so would powedercoating hold up to the heat of the header? and can you powder coat ceramic coated stainless steel or does it have to be stainless steel? also you can take off a header without yankin the motor out right? doesnt it just need to be up on a lift?
Old Mar 8, 2004 | 11:08 PM
SCintegra's Avatar
Default Re: painting my header (iuseamsoil)
Im personally not to familiar with powder coating. I know what it is, I just dont know if I would ever powder coat a header. I havent even seen that done before.
But to answer your question about "yankin" the motor, you dont have to. The only things you need to do to remove your header are romove the bolts that hold it onto the block, and either get the car on a lift (if you have one) or just jack it up and put it on jack stands. There are a couple of bolts connecting it to the cat.
Old Mar 8, 2004 | 11:14 PM
W.O.P.'s Avatar
Default Re: painting my header (SCintegra)
just unbolt the top end of the header if its a 2pc. then paint that. thats the only part you see
Old Mar 9, 2004 | 12:00 AM
B00ST2nR's Avatar
Default Re: painting my header (RedLinedGSR)
Check this out:
http://www.hpcoatings.com/hipercoat.htm
Old Mar 9, 2004 | 07:47 AM
iuseamsoil's Avatar
Default Re: painting my header (Skunk2nR)
skunknr- thanx for that site i just called them its gonna be $200 dollars though.
prejdmlude
Nov 11, 2006 01:28 PM
98vtec
Welding / Fabrication
Mar 17, 2005 06:37 PM
xmr. robotox
Feb 27, 2005 07:08 PM
Bigjussin
Sep 16, 2004 03:37 AM
cccya
35
Dec 11, 2003 12:40 PM
