B20VTEC, 225 WHP possible?
Old Mar 8, 2004 | 08:27 PM
d0ppleganger's Avatar
Default B20VTEC, 225 WHP possible?
Current setup:
B20VTEC
ITR head
B20 block : 11.8 compression
toda B cams/cam gears/valvetrain
ITR intake manifold/throttle body
intake/jdm 4-1 header/GReddy Evo exhaust
6A MSD ignition/HVC Coil
Walbro fuel pump/fpr/fuel pump
p28 comp
Apexi VAFC
Currently at 200 whp, will JUN 3 cams, port/polish head, and hondata get me to 225 whp?
Old Mar 8, 2004 | 08:58 PM
marieT1GRL's Avatar
Default Re: B20VTEC, 225 WHP possible? (d0ppleganger)
https://honda-tech.com/zerothread?id=746126
hell yeah
Old Mar 8, 2004 | 09:50 PM
Rob Dizzle's Avatar
get jun 3's instead of toda, and hondata versus vafc and you should be pretty damn close
Old Mar 8, 2004 | 09:54 PM
Kendall's Avatar
I think it heavily weighs upon the headwork. Who will be doing it, and what exactly will be done?
Old Mar 9, 2004 | 06:25 AM
DavidR's Avatar
to reach that, you'll need more/better components.
I had a B20/vtec with Alaniz ported head, CTR cams, ITR IM, JDM 4-1, Hondata, 440cc injectors, overbore TB and a few other things, I maxed out at 200/153. You will have to open it up more, it needs more air, and more fuel, get a ported IM, bigger head, and a much bigger header.
Old Mar 9, 2004 | 07:59 AM
Rob Dizzle's Avatar
Default Re: B20VTEC, 225 WHP possible? (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">to reach that, you'll need more/better components.
I had a B20/vtec with Alaniz ported head, CTR cams, ITR IM, JDM 4-1, Hondata, 440cc injectors, overbore TB and a few other things, I maxed out at 200/153. You will have to open it up more, it needs more air, and more fuel, get a ported IM, bigger head, and a much bigger header. </TD></TR></TABLE>
stock b20 bottom end?
Old Mar 9, 2004 | 09:07 AM
EKhatch's Avatar
Default Re: B20VTEC, 225 WHP possible? (Bob-DC2)
Should be able to get there without much more help.
Here is 205whp on a stock bottom end with just JUN 3's. Old post so pics don't work anymore.
https://honda-tech.com/zerothread?id=631392
So that is with way less compression than you are dealing with. Get Hondata and get it tunned.
Old Mar 9, 2004 | 09:29 AM
Rob Dizzle's Avatar
Default Re: B20VTEC, 225 WHP possible? (EKhatch)
ekhatch if you email them to me, i can host them on my server so they are always up
i need to support the stock b20 bottom end folk
Old Mar 9, 2004 | 09:34 AM
EKhatch's Avatar
That was advanracing62's motor he may still have the pics.
The only pics I have are of the stock B20 pistons that I enlarged the valve reliefs on. I can send you those if anyone is interested in seeing them?
Old Mar 9, 2004 | 10:04 AM
Rob Dizzle's Avatar
sure, so thats pretty much the only way to run vtec head/cams on a stock b20 bottom end right. to do the valve relief stuff by hand?
Old Mar 9, 2004 | 11:51 AM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">sure, so thats pretty much the only way to run vtec head/cams on a stock b20 bottom end right. to do the valve relief stuff by hand?</TD></TR></TABLE>
Yeah since the face of non-vtec valves are smaller in circumference then vtec ones. You may be safe with stock cams. We were running JUN 3's with cam gears set at zero and they were barely hitting as you will se in the pics which I will send out latter tonight.
Old Mar 9, 2004 | 03:43 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah since the face of non-vtec valves are smaller in circumference then vtec ones. You may be safe with stock cams. We were running JUN 3's with cam gears set at zero and they were barely hitting as you will se in the pics which I will send out latter tonight. </TD></TR></TABLE>
pictures will be very helpful
Old Mar 9, 2004 | 04:47 PM
EKhatch's Avatar
Default Re: B20VTEC, 225 WHP possible? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
pictures will be very helpful </TD></TR></TABLE>
Still being able to link from imagestation would be very helpful also.
I will get the pics sent to Bob in the next couple of hours.
Old Mar 9, 2004 | 07:40 PM
EKhatch's Avatar
Old Mar 9, 2004 | 10:32 PM
JDM2ndGen's Avatar
dam you can really tell where the valves were hitting ...and thats a good job on opening up the reliefs looks good
Old Mar 10, 2004 | 08:19 AM
EKhatch's Avatar
Default Re: B20VTEC, 225 WHP possible? (JDM2ndGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">dam you can really tell where the valves were hitting ...and thats a good job on opening up the reliefs looks good </TD></TR></TABLE>
Thanks.
Ignore all other valve marks outside the relief area. That was from when the motor was stock and an old guy towed his CRV at 50-60mph while it was IN GEAR.
Old Mar 10, 2004 | 01:50 PM
smokey2.0's Avatar
hey nice picture , those will really help anyone trying to do the samething(like me). this was a topic, that has been covered before but no one ever showed pictures of what the process is like! how did you manage to keep the shavings, from entering the cylinder walls. i was thinking of using a shop vacum, while my friend grinded of the valve reliefs!
Old Mar 10, 2004 | 01:58 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">how did you manage to keep the shavings, from entering the cylinder walls. i was thinking of using a shop vacum, while my friend grinded of the valve reliefs! </TD></TR></TABLE>
Lots of duc tape.
Not really ideal to do it with the pistons installed but hey, you gotta do what you gotta do.
Old Mar 10, 2004 | 02:52 PM
BERT-O's Avatar
*cough cough, sniff sniff, lol
I hate ******* pollen season right now
But hey, check these out,
Give me about 6 months and you'll see
-Bert
Old Mar 10, 2004 | 03:06 PM
Rob Dizzle's Avatar
Default Re: B20VTEC, 225 WHP possible? (BERT-O)
what are those mr bert?
Old Mar 10, 2004 | 03:12 PM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">what are those mr bert?</TD></TR></TABLE>
Just stock CRV pistons........................ for now
Old Mar 10, 2004 | 06:17 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
Just stock CRV pistons........................ for now </TD></TR></TABLE>
For now eh.
Old Mar 11, 2004 | 02:36 PM
BERT-O's Avatar
For now eh. </TD></TR></TABLE>
You guys will see, I won't give anything out till is finish. Don't want none of this politcal crap that I see here everyday.
-Bert
Old Mar 11, 2004 | 04:20 PM
EKhatch's Avatar
-Bert</TD></TR></TABLE>
You can tell me. I wil play nice.
d0ppleganger
Feb 22, 2004 09:17 PM
VtecDA9
Oct 21, 2003 07:09 PM
jdmFantasyEk9
Oct 12, 2003 02:54 PM
all motor b20b
32
Aug 23, 2003 06:02 PM
civicguy
32
Feb 15, 2002 05:41 PM
