1998 Accord V6 won't start
It turns over just fine, but it will not start
the drive light for the trans blinks, but no dice
the car is wrecked right now and i plan on buying it to fix if i can start it.
any ideas or links to info? i'd really like some links for more info on the car.
Thanks!
Thanks!
Wasn't there a recall on the ignition switch...if you haven't registered with honda.com typing in your VIN number I would recommend it, they will mail you discounts for scheduled maintanence and recall info too
anyone know for sure if there was one?
i don't own the car, but i'm planning on buying it.
does anyone know of there is a fuel pump cut off?
thanks
thanks
thank you very much for the ideas
i believe it to be the correct key as it has the black plastic end with the honda emblem.
i'll check the shut off ASAP
thanks again!
thanks again!
we got it started today, turns out that the battery was busted up in the accident and must have been shorting something out. we disconnected the positive side of the battery and connected a jumper pack and it started right up.
thanks for the help!
Charlie32
Nov 22, 2014 04:43 PM
lord_old
Jun 1, 2004 05:52 PM
